max232
7.1.1 firewall connection
Sun Jan 02, 2022 9:55 pm
regularly command:
ip firewall connection print count-only
results in an error: script error: no such item (4)
I've tried isolating the command with:
: do {} on-error = {)
It doesn't help either.
The problem has been going on in my memory since 2016.
I'd like to solve it very much.
Maybe someone knows a solution?
I understand that the number of records is constantly changing.
But this is a statistical command, which, in principle, should not lead to an error.
ConnyMercier
Forum Veteran
Forum Veteran
Re: 7.1.1 firewall connection
Mon Jan 03, 2022 1:06 am
Can you elaborate more on how you use the command,
and maybe provide the Script or Scheduler you use it in ?
I quickly tested the command in a script without error on both 6.49.1 and 7.1.1
max232
Mon Jan 03, 2022 1:11 am
ip firewall connection print count-only where dst-address~":1701"
For instance.
I have multiple routers.
This problem is on those routers with a lot of connections (3000 - 10000).
Every second the amount changes dramatically.
The problem appears in about 25% of requests
for x from=0 to=100 do={ip firewall connection print count-only where dst-address~":1701";ip firewall connection print count-only where src-address~":1701"; }
Run this loop in terminal and you will see the problem
https://ibb.co/Jnv9hXq
ConnyMercier
Forum Veteran
Forum Veteran
Mon Jan 03, 2022 2:07 am
Try this,
/ip firewall connection print count-only interval=1 where dst-address~":1701" || src-address~":1701"
max232
Mon Jan 03, 2022 1:28 pm
Try this,
https://ibb.co/qxXwR1d
I've tried many different options.
The problem is in RouterOS
/ip firewall connection print count-only interval=1 where dst-address="xxx.xxx.xxx.xxx:1701" || src-address="xxx.xxx.xxx.xxx:1701"
And that doesn't work either
Users browsing this forum: abbio90 and 73 guests
