mrgmrg
Wanted to add this to previous post but
Wed Jan 05, 2022 3:40 am
it seems since its "pending moderation" it doesn't even let ME see it.
I've found this documentation, but it doesn't touch on "how to ADD a package". It shows where to download them, and how to manage the ones on the router.
But it completely ignores "how to add them to the router"
there is an "uninstall" but not "install" - these seems like a glaring omission.
https://wiki.mikrotik.com/wiki/Manual:System/Packages
anav
Re: Wanted to add this to previous post but
Thu Jan 06, 2022 8:08 pm
Unzip it if its extra packages otherwise three steps
Open the Files menu selection in Winbox
Drag the file(s) from your local folder/deskop onto the file menu area and watch them automatically load up.
Reboot the router (under system I believe)
mrgmrg
Thu Jan 06, 2022 8:59 pm
As i said in the previous post, which i was unable to add this reply to due to it pending moderation, i do not, cannot use "winbox"
This documention is for the cli. There is documentation there for listing installed packages and uninstalling a package. Neither of those involve "winbox"
There should be a section there on how to INSTALL packages. Using the cli and/or web browser only.
anav
Thu Jan 06, 2022 9:02 pm
Did you try using the MT app on your smartphone??
mrgmrg
Thu Jan 06, 2022 9:05 pm
Using a desktop pc with chrome browser.
Or ssh via linux commandline. No windows, no apps.
No windows, no smartphone.
Why isnt this documented ON that page i linked?
BartoszP
Thu Jan 06, 2022 10:15 pm
mrgmrg
Thu Jan 06, 2022 11:58 pm
That's to update the OS, not for adding packages.
The documentation for managing packages at the URL below *completely ignores* the topic of "How to install NEW packages"
There should be a "/system package install" command, or something like that.
Or at the very least, there should be *something* on the page acknowledging that one might want to install packages, and how to do so (that uses only "routerOS" and does not require "winbox")
Sob
Fri Jan 07, 2022 12:34 am
mrgmrg
Fri Jan 07, 2022 12:51 am
Maybe that should be documented somewhere on the System/Packages page.
It baffles me why there simply isn't a "upload" option in the Web UI under the "System, Packages" menu that would use http upload ....
Sob
Fri Jan 07, 2022 1:53 am
There's upload in Files. And yes, how to install packages should be documented.
Users browsing this forum: Bing [Bot], Irish9 and 87 guests
