elexx
VLANs are not switched between trunk ports?
Sat Jan 08, 2022 11:36 am
Hello!
The idea
The setup is heavily based on pcunite's guide to VLANs viewtopic.php?t=143620 with added support for CAPsMAN in local forwarding mode, the idea being CAPsMAN uses the BASE_VLAN (99) for configuration and the actual VLANs for user-wifi-data.
RB3011 (called Main)
Main-20220108-0014.rsc
Working as router between the VLANs and WAN. Connected to WAN (ether1), trunks (ether6 and ether9), accessport vlan10 (ether10)
RB952Ui (called EG)
EG-20220108-0014.rsc
Working as accesspoint+switch: connected to trunk (ether1 -> Main-ether6), accessports vlan10 (ether 2-5)
RBD52G (called DG)
DG-20220108-0014.rsc
Basically the same as EG
Working as accesspoint+switch connected to trunk (ether1 -> Main-ether9), accessports vlan10 (ether 2-4), accessport vlan 99 (ether5 - this is just for debugging, once everything works this will be vlan 10 too)
Problem
My problem is: When connected to WIFIintern (vlan 10) or EG/DG accessport for vlan10, I cannot reach Main-ether10.
Also, if I'm connected to my vlan99 debugging port (DG-ether5), I can only reach DG and Main via Winbox/Web, but not EG.
What I tried so far
As you can see, there is currently a rather strange and unexpected firewall rule in the forward chain: "add action=accept chain=forward comment="WHY\?!" in-interface=BR1". Once I added this rule I was able to get both problems resolved, BUT this also activated VLAN<->VLAN routing, which I don't want. Once the rule is disabled I can only reach "1 hop" basically, but it looks like Main is not switching between the 2 Main-trunk ports (Main-ether6/9) or between the trunks and the accessport (Main-ether10)
I also noticed a dynamically added entry in /interface bridge vlan print (on all 3 devices, output below is from Main, entry #4), which I don't understand. Where does this come from? Is this the culprit?
[admin@Main] > /interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE                      VLAN-IDS  CURRENT-TAGGED                      CURRENT-UNTAGGED
 0   BR1                         10        BR1                                 ether10
                                           ether6
                                           ether9
 1   BR1                         20        BR1
                                           ether6
                                           ether9
 2   BR1                         30        BR1
                                           ether6
                                           ether9
 3   BR1                         99        BR1
                                           ether6
                                           ether9
 4 D BR1                         1                                             BR1
I'm stuck and would really appreciate your help!
elexx
Sob
Re: VLANs are not switched between trunk ports?  [SOLVED]
Thu Jan 13, 2022 4:53 am
You most likely don't want use-ip-firewall=yes use-ip-firewall-for-vlan=yes on bridge. That's for advanced use only and can produce very unexpected results otherwise. Like what you're seeing.
elexx
Thu Jan 13, 2022 8:47 am
Wow, that was easy! Setting those 2 to no fixed the problem. Thank you very very much!
Users browsing this forum: anav, Bing [Bot], Google [Bot] and 63 guests
