ayene
hotspot login page disconnect after while
Sat Jan 08, 2022 8:48 pm
hi. I setup hotspot for about 200 user and it work fine in ROS 6 but after update to V7 hotspot crash. when user successfully login and after about 1 minutes they disconnect and cant see any page involve logging page or status page. But if I use IP Binding it work nice and don't disconnect.
Zacharias
Re: hotspot login page disconnect after while
Sun Jan 09, 2022 8:28 pm
There are many changes on the Hotspot between versions 6 and 7...
When you use the IP Binding you bypass the user from the hotspot so it is normal that the user stays connected...
I would suggest you review all the configuration...
Lorsk
Mon Feb 21, 2022 2:59 pm
exactly same behavior on my side (tested also with ROS 7.2rc3)
I also opened a ticket at mikrotik - no solution till now.
It could also be the same topic as here: viewtopic.php?p=912251
By the way - I disabled hotspot service (so it is a basic router) and everything works fine and stable - so it has to be an issue with the hotspot package.
allan2358
Thu Mar 03, 2022 12:18 pm
same... hope to fix this issue in the next release.
Lorsk
Wed Mar 30, 2022 3:56 pm
... no response from Mikrotik until now! (Ticket is also unanswered for almost 14 days)...
Please help.
holvoetn
Wed Mar 30, 2022 4:48 pm
Which version of v7 ?
There are quite some changes in 7.2rc4. Latest now is rc6.
Lorsk
Thu Mar 31, 2022 3:07 pm
7.2rc5 also doesn't address this problem - I could try rc6 but I don't think that there is any help because I didn't got response to my ticket!
Just checked changelog - even in rc6 and rc7 no changes to hotspot package.
Lorsk
Fri Apr 01, 2022 12:47 pm
... just downgraded to ROS 6.49.5 - and hotspot seems to work.
Therefor I can exclude settings, hardware, network related issues and so on. It is only verion of ROS respective version of hotspot-package.
Lorsk
Wed Apr 06, 2022 11:20 am
... why there is no reaction on my problem (and also others reported this issue - so I'm not alone with this "bug")? ...
loloski
Wed Apr 06, 2022 12:20 pm
you are not alone we also already file a support ticket and MT was able to reproduce the issue, our case is we setup hotspot with external AP after login the client is working for quite sometime and goes haywire, from client we can ping the ip address of the AP but not the MT router side, this affects all v7.x including the latest stable 7.2, we even try 7.3beta27 as per the support suggestion and still the problem still there. we can reproduce this so easily on RB4011 and RB5009 respectively
Lorsk
Wed Apr 06, 2022 2:29 pm
Thanks a lot for the feedback - so Mikrotik could reproduce this issue on their own equipment? Then I have to wait until a solution is done by MT.
I was only scared because I didn't got any feedback by Mikrotik (expect of "we can't see any failure on your setup and can't reproduce it")
loloski
Thu Apr 07, 2022 10:43 am
Yes that what they say they were able to reproduce the issue, the sad part is there's no commitment time for the said fix, since we do have a workaround i think for now it's better than nothing, at least this was queued on their list.
sergejs
Tue Apr 12, 2022 1:22 pm
We are working on the fix for the particular issue. Hopefully it will be fixed shortly.
embops87
Wed May 11, 2022 3:15 am
Which routerboard were you using for these 200 users? And which version of RouterOS 6? I have an RB750gr3 that works fine in v7.2.rc3 for ~20 users, but when I put it to work with ~170, the same situation occurs as in your case.
swa69er
Tue May 17, 2022 5:16 am
I'm planning to buy RB5009 for hotspot. Is this still a problem in v7?
loloski
Tue May 17, 2022 1:35 pm
basic hotspot + queue is working properly now starting v7.3beta37
swa69er
Fri May 27, 2022 7:53 am
trying on beta40 still disconnect after a while
my solution is trying to reboot several times :D
loloski
Sun May 29, 2022 12:49 pm
hi,
don't know if it make a difference, i failed to mentioned that i have external AP connected in MT poe port on RB5009
Lorsk
Tue Jun 28, 2022 10:48 pm
Seems to be solved in 7.4 Beta 4 or 5
Users browsing this forum: No registered users and 51 guests
