hkusulja
User Manager 7.1.1 questions
Sun Jan 09, 2022 12:52 am
I am long time Mikrotik user, but never user "User Manager" . Now, with RouterOS 7.1.1 stable I have installed User Manager 7.1.1 stable package.
Since it seems documentation is not finished, https://help.mikrotik.com/docs/display/ ... ager-Users
I have several questions:
1. Is there a web access for web administration?
I do have access to https://myrouter.domain.com/um URL with working log-in for end-user. Any other URL should i look into (/user or /userman) returns 404 for me.Is this expected?
I do not see option that user can change its password in UM portal, What am I missing?
2. Can somebody please clarify, what is /user-manager/users , field "otp-secret" and how to use it?
3. Is it possible that user is identified with client certificate fro VPN / PPP access, instead of username/password?
I am using Mikrotik as SSTP vpn server with User Manager as RADIUS on localhost. Working with MSCHAPv2 and user+pass is working.
What else i need to configure if i want to use user+pass with EAP-MSCHAPv2 as VPN? It seems that User manager supports it, but Mikrotik SSTP server does not. Can you confirm / clarify? Tx
4. Is user manager ports (1812 and 1813) opened on all mikrotik device IPv4 and IPv6 addresses? If so, can I use ip firewall for input chain to control (accept/reject) network traffic from other network devices? or user manager has its own some alternate ip address in some subnets?
5. How to specify which /user-manager/router device (with ip and secret) is used for which user/groups ?
I am planning to run one instance of user manager as local RADIUS server, for multiple network devices (switches, routers, wireless, vpn) therefore i need to specify user groups per network device.
Better example, one user must have access to VPN but not WiFI on same user manager.. Or should I play with Attributes on User Group level based on request type?
6. Is there any documentation alternative? If I move to dev or test channel, how can I know and test new features on user manager if no info on how to use it / which CLI commands to run
Sob
Re: User Manager 7.1.1 questions
Sun Jan 09, 2022 1:01 am
I don't know much about the rest, but v7 has UI for User Manager in WinBox (left menu, third item from top).
hkusulja
Sun Jan 09, 2022 1:30 am
Thank you, that was my mistake. I also see it in WebFix, which is great. Thank you
Still hoping for other answers/clarifications.
I also found update documentation on example with Wireless, that did help somehow - https://help.mikrotik.com/docs/display/ ... Manager+v5
sbhokray
Tue Jan 25, 2022 6:02 pm
did you find anything about the OTP thing?
m94646602
Sat Jan 29, 2022 6:07 pm
ministryofspoons
Tue Feb 01, 2022 12:19 am
I have this same question , how do I access the WebUI version of user manager. I am using 7.1.1
kvee
Mon Aug 28, 2023 3:23 pm
Web UI version of user manager is in the same place where Mikrotik RouterOs admin page is. It's on the left menu same position as in Winbox; desctibed by @Sob.
Users browsing this forum: No registered users and 15 guests
