Navegador
LtAP main board dimensions / mounting screw locations
Sun Jan 09, 2022 10:40 pm
Hi everyone. I'm planning on using a LtAP with my own LTE modem (Quectel EM12G) inside a Poyting ePoynt antenna enclosure. This takes routers and router boards of up to 185 x 145mm, so the entire LtAP doesn't fit inside, but its main board might, if I take the case apart. Mikrotik's website naturally has the assembled product dimensions, not the motherboard's. I bought the Poynting enclosure but haven't acquired the router yet; does anyone have and/or can provide LtAP board dimensions and, if possible, mounting screw distances?
Thanks in advance.
Sob
Re: LtAP main board dimensions / mounting screw locations
Sun Jan 09, 2022 11:04 pm
Navegador
Sun Jan 09, 2022 11:39 pm
Excellent, thank you. I'm assuming the connectors on the topside, bottom right & centre are for external wifi antennas or a 2x2 MIMO setup? Are those MMCX, TS9 or can anyone make out what type of connector is that?
Thanks again in advance folks!
krafg
Mon Jan 10, 2022 2:21 am
MMCX connectors are only for testing, not for increase Wi-Fi gain.
Regards.
Navegador
Mon Jan 10, 2022 3:08 am
Good to know, thanks.
ciotóg
Mon Jan 17, 2022 12:41 am
I'd be interested in hearing how you get on with this - I've been thinking about this type of project too (I'm a fan of Poynting antennas)
Navegador
Tue Jan 18, 2022 12:27 am
I'll be sure to post my setup and results here as soon as my Poynting enclosures arrive (I have the two models on order). In the meantime, I know this won't be Mikrotik Forum but I posted my test setup on Reddit. It's been chugging along nicely with very basic IoT antennas but strangely an indoor TP-Link cat6 router easily outperforms it now (approx. 150mbps down for the cat12 prototype installed outdoors and near the roof, 220mbps+ for the TP-Link).
ciotóg
Wed Jan 19, 2022 1:04 am
That's an excellent read! Thanks
Users browsing this forum: No registered users and 79 guests
