ranpha
For those who has Wireless Wire Cube
Mon Jan 10, 2022 2:09 am
Has anyone with Wireless Wire Cube wall mount their installation? If yes, how did you do it?
ConnyMercier
Forum Veteran
Forum Veteran
Re: For those who has Wireless Wire Cube
Tue Jan 11, 2022 1:48 pm
I used different solutions in the past...
Solution 1: Custom Adapter
We build for a customer a custom Holder based on the Mikrotik QMP
https://mikrotik.com/product/QMP-LHG
I you don`t have the tools or Workshop to jerry-rig you own Adapter.
Maybe the Mikrotik QMP can be easily modified for the WireCube
** Never owned a QMP-Adapter, so no garanties =)
Solution 2: Satellite dish mount
You can usually buy for ~ 20$ Wall-Mounts for sateliite dishes
Solution 3: Ubiquiti Mount
Ubiquiti sells a Wall-Mount(very similar to a satellite dish mount) for around ~20$
Productmodell: UB-AM
timotei
Wed Jan 12, 2022 9:56 am
Never had any Wireless Wire Cube, but I expect QMP to be OK?
With QMP you get both the mounting clip for SXT/DISCLite series and a small pole adapter. Use the pole adapter.
https://i.mt.lv/cdn/rb_images/1445_hi_res.png
QM and QME are next step in size.
I use the already suggested UB-AM for bigger antennas, like Dynadish.
ranpha
Mon Jan 17, 2022 10:21 am
Ok, just received the Mikrotik quickMOUNT extra thing, and it works perfectly.
Users browsing this forum: No registered users and 77 guests
