thavinci
KVM ROS v7x
Tue Jan 11, 2022 4:16 pm
Just realized after upgrading a number of my units/installations that KVM is not available as part of the v7 base or additional packages.
Is this no longer supported or anyone know if the team is working on this currently?
Sob
Re: KVM ROS v7x
Tue Jan 11, 2022 5:56 pm
KVM and MetaRouter is removed, Container will come as a replacement for all platforms.
thavinci
Re: KVM ROS v7x
Tue Jan 11, 2022 6:23 pm
Thank you for the response.
Wonder if we could request a migration of license from x86 to CHR in this case, as it would render the current use (For some some instances), useless.
Sob
Re: KVM ROS v7x
Tue Jan 11, 2022 6:46 pm
Looks like you can:
Moving to the faster and more modern CHR is free, email us, we will issue you license for CHR.
thavinci
Re: KVM ROS v7x
Tue Jan 11, 2022 6:53 pm
Your a legend, thank you.
If I may ask though, where did you find the info?
Sob
Re: KVM ROS v7x  [SOLVED]
Tue Jan 11, 2022 7:03 pm
I'm reading this forum a lot and random details stick in my memory. In this case I remembered that someone from MikroTik mentioned KVM (I guessed @mrz and I was right) and that @normis mentioned license. And you can thank site's search function for the rest:
search.php?keywords=kvm&author=mrz
search.php?keywords=license&author=normis
Users browsing this forum: No registered users and 40 guests
