DarthNibbles
Disable IPv4 on a single port?
Wed Jan 12, 2022 2:39 am
Hey guys, I have an unusual situation where the easiest solution is to limit a specific device on my network to IPv6 only. I cannot disable IPv4 on the device itself because it's configured by my employer. I can't simply block IPv4 traffic to that device because it will think it doesn't have internet access and will throw a hissy fit. The easiest solution really seems to be to simply not assign it an IPv4 address. So I'm looking at either limiting the v4 DHCP to a set of ports, or just disabling it completely on the router. I did a test-run of only IPv6 on a personal machine for a few days without issue, so I'm not worried about giving up IPv4 - I just want to do whatever is simplest.
Any suggestions on how I could do this, or pointers for where I should look for more information?
DarthNibbles
Re: Disable IPv4 on a single port?
Wed Jan 12, 2022 8:27 am
Figured it out, I checked the IPv4 leases for the mac address of the device, converted the lease to static, and blocked the lease! IPv6 works on the device just as it should.
Users browsing this forum: Amazon [Bot], GoogleOther [Bot], intania, voytecky and 85 guests
