karyal
Upgrading "expired" license - no windows
Mon Sep 03, 2007 11:13 am
Hi, i know it's possible to upgrade an "expired" licence lev. 4 by using netinstall.
Is it possible to upgrade in a similar way if there is no Windows box around?
Thanks,
ricky
normis
Re: Upgrading "expired" license - no windows
Mon Sep 03, 2007 1:43 pm
Licenses don't expire. read this for all license info;
http://wiki.mikrotik.com/wiki/All_about_licenses
karyal
Mon Sep 03, 2007 1:57 pm
Ok, i was not clear enough.. i have a licence i cannot upgrade anymore (it's a 2.9.25 or 26) and as you know you can still upgrade to new version, but you need netinstall.
I cannot use netinstall as i don't have a windows box, neither wine, it's a routerboard so no removable flash memory..
Is it possible to upgrade someway?
Thanks,
ricky
sergejs
Tue Sep 04, 2007 2:08 pm
You may try to find Windows box or run with VMware to run netinstall,
I think it should be cheaper rather than buy new license (especialy when you can avoid it).
karyal
Tue Sep 04, 2007 2:18 pm
Ok, so the answer is netinstall must be used some way.. thank you!
Ricky
petecarlson
Sat Oct 06, 2007 10:09 pm
As far as I understand, netinstall is just a pxe boot server. Easy to run under Linux etc.
Users browsing this forum: Baidu [Spider], Matta and 33 guests
