Filo
New to RouterOS: Can RB941-2nd create a non-natted but secure part of the existing network?
Thu Jan 13, 2022 2:51 pm
Greetings to all,
Current Situation at my home-network:
- 1 Subnet (192.168.178.0/24) with DSL-Hardware (FritzBox) doing DHCP, all clients are connected to WLAN / LAN to this box.
Situation I'd like to realize:
- Still 1 Subnet (192.168.178.0/24) wit DSL-Hardware doing DHCP
- RB941-2nD Connected to Router (kind of acting as a Switch), DHCP-Proxy set, (ether1, 192.168.178.xxx)
- "Special" Devices I'd like to firewall connected to RB941-2nD (ether2 - ether4, 192.168.178.x)
- Firewall-Rules control traffic of connected devices (ether 2 - 4) to OTHER Devices connected directly to FritzBox and / or the Internet
What I realized:
Everything above, but with a separate Subnet on RB941-2nD and NAT.
So with my beginner's knowledge to RouterOS I'm only able to create a second Subnet and work with NAT and Firewall-rules.
The Reason why I'd like to have everything in ONE subnet is based on some services relying on broadcast (e.g. a MineCraft-Server on Raspi which is otherwise not found as a "local game" for my kids and they would need to sign in to Microsoft to connect...)
Is this even possible? I tried to bridge all ports but this is giving me the same subnet (which is good), but firewall-rules are not possible for a bridged network... am I correct?
Thanks for your Ideas appreciate your input to this,
Stay safe,
Martin!
Sob
Re: New to RouterOS: Can RB941-2nd create a non-natted but secure part of the existing network?  [SOLVED]
Thu Jan 13, 2022 7:00 pm
Two options:
- If it would be enough, you can use bridge filters for stateless config (e.g. A can't connect to B, and neither can B connect to A)
- If you want stateful firewall (A can connect to B, but B can't connect to A), you can use bridge's use-ip-firewall=yes, and then you'll see all bridged connections in IP firewall.
Filo
Thu Jan 13, 2022 7:32 pm
[...]you can use bridge's use-ip-firewall=yes, and then you'll see all bridged connections in IP firewall.[...]
So you mean, the only thing I forgot is to edit Bridge SETTINGS (which I found after reading your post) to activate the setting "Use IP-Firewall"?
This would result in having all firewall-options available although all ports are using the same bridge? If it's THAT easy, it's a quick win and a big "thank you" for your post!
Sob
Thu Jan 13, 2022 7:47 pm
If it helps you, that options is not used very often. And when it's mentioned somewhere, it's usually warning to not use it, because its effect in some configs can be a bit unexpected. But for filtering within local subnet, as you want, that's the thing.
Filo
Thu Jan 13, 2022 8:41 pm
Thanks Sob - it solved my desired configuration!
Plus: I added a secondary bridge for keeping the option to have a separated network, so the Routerboard can handle my "normal"- and my "lab"-network.
Firewall now seems to have the need to be reconfigured (I get a ton of "invalid" connections now and need to check why...),
but generally your solution was very helpful - THANKS!
Sob
Thu Jan 13, 2022 9:43 pm
That's the possibly tricky part, there's only one common IP firewall, so if router does some other routing, firewall will see both that and bridged packets.
Filo
Fri Jan 14, 2022 3:42 pm
It is a littly tricky, right. I'm approaching it with Address-Lists at the moment.
Also I have in mind (for a more professional avail) to use VLANs for those different networks in the future and only use ONE bridge for multiple VLANs.
Absolutely a good idea to check back to this forum if something is stuck then, skilled people are around here!
Thanks,
Martin!
Users browsing this forum: complexxL9 and 45 guests
