netaneldanner
HELP! route multicast+broadcast packets from LAN to VPN network vice versa
Thu Jan 13, 2022 7:16 pm
Hello, I am currently struggling to route and receive multicast and broadcast packets between LAN and VPN (OVPN Server) networks. LAN is 1.1.1.0-150 and to make somehow easier to follow, made VPN hosts are 1.1.1.151-250. How can I route to and from LAN broadcast and multicast packets. Thanks-
LAN IP range: 192.168.1.1-150
VPN range: 192.168.1.151-250
Last edited by netaneldanner on Thu Jan 13, 2022 10:14 pm, edited 1 time in total.
jwreno
Re: HELP! route multicast+broadcast packets from LAN to VPN network vice versa
Thu Jan 13, 2022 8:18 pm
I'm curious. Why are you using cloudflare's IP block and not a private IP?
netaneldanner
Thu Jan 13, 2022 10:10 pm
IP numbers are just example
jwreno
Thu Jan 13, 2022 11:22 pm
I see. :lol:
This is way beyond anything I've ever tried, but perhaps something like arp proxy will do the trick. **shrugs**
netaneldanner
Thu Jan 13, 2022 11:40 pm
I see. :lol:
proxy-arp is activated on bridge interface, on vpn side I dont get neither ARP broadcast, nor layer 3 IP broadcasts of LAN network. But I can reach and talk to hosts on LAN network from VPN side.
Sob
Fri Jan 14, 2022 12:45 am
Multicast can be routed, but I don't know much about that. Broadcast not so much. Some (255.255.255.255) can't at all. Some (directed broadcast to 192.168.1.255) can, but AFAIK RouterOS doesn't support that (I can't even find if underlying Linux does). Another way would be some broadcast relay/proxy as process or router, but RouterOS doesn't have that either.
jwreno
Fri Jan 14, 2022 10:51 am
Surely a layer 2 vpn would do the trick. Apparently ovpn can do L2, but I've never needed it so not sure.
Looking over here, perhaps OpenVPN TAP (not TUN) will work?
Remember I don't know what I'm talking about because I've never needed anything like this. :lol:
- Reno
Users browsing this forum: CGGXANNX and 65 guests
