bolsblue
DNSSEC Problems (large UDP packets)
Fri Jan 14, 2022 12:16 am
Hi!
I have a problem with my DNS solution and hope to find help here.
Currently I'm trying to run a pi-hole with unbound as a DNS resolver. However unbound won't resolve any names.
I'm pretty sure it's the large DNSSEC UDP packets that somehow get dropped (?) by the MikroTik, because the exact same setup is working flawlessly with a FritzBox router.
Also choosing any other upstream DNS server without DNSSEC is working without a problem.
If unbound is running and I change the router from the FritzBox to the MikroTik, it can still resolve normal DNS requests (which are quite small I guess), however if I then restart unbound it wont resolve anything anymore. I guess that's because then it's contacting the root servers at start which give these huge replies...
This is really frustrating, I did quite some research and searched the net and forum, but I haven't found anything that could help me.
Clearly I can't be the only one with this setup...
Does anybody have some hints at what to do?
Sob
Re: DNSSEC Problems (large UDP packets)
Sat Jan 15, 2022 9:37 pm
If you want to be completely sure, packet sniffer is your friend. But if it's just packets passing through router, it's like any other udp traffic, RouterOS doesn't have anything against that.
msatter
Sat Jan 15, 2022 9:45 pm
Set Unbound to use a packet size of 1232 and if bigger is returned it swtches over on TCP/53 so you need also accept that in your firewall.
sindy
Sat Jan 15, 2022 9:48 pm
I've recently seen a case where huge packets came in via WAN, got reassembled, and got forwarded to a LAN destination without fragmentation because the mtu parameter of the bridge was left at auto and all the member ports had MTU larger than the popular value of 1500. So here too, if the recipient (running the pi-hole) has a smaller MTU than what is set on the bridge/member ports, packets exceeding recipient's MTU get lost. Sniffing will show the size of the received and sent "versions" of packets.
sindy
Sat Jan 15, 2022 9:52 pm
@msatter, are you saying that when the query response is too big, the DNS server initiates a TCP session to the sender of the query?
msatter
Sat Jan 15, 2022 10:34 pm
..are you saying.... brrrr Channel 4 News fibes also overhere?
https://m.youtube.com/watch?v=aMcjxSThD54
No, it does tell on request the size that will fit.
Unbound:
edns-buffer-size: <number>
Number of bytes size to advertise as the EDNS reassembly buffer size. This is the value put into datagrams over UDP towards peers. The actual buffer size is determined by msg-buffer-size (both for TCP and UDP). Do not set higher than that value. Default is 1232 which is the DNS Flag Day 2020 recommendation. Setting to 512 bypasses even the most stringent path MTU problems, but is seen as extreme, since the amount of TCP fallback generated is excessive (probably also for this resolver, consider tuning the outgoing tcp number).
Mikrotik: max-udp-packet-size: 4096 Wiki on this: Maximum size of allowed UDP packet. Docs is silent on this setting.
sindy
Sat Jan 15, 2022 10:48 pm
Bear in mind that my native language is a bit more different from English than yours, so what exactly is wrong about "are you saying" as compared to "do you have in mind that" or some other phrase equal to "please clarify:"?
msatter
Sat Jan 15, 2022 11:35 pm
English is also not my native language, but it serves well as a kind of Esparato and is very simple language that can be used around the world.
When you watch the video you will see why it projects as a negative fibe towards many. It implies that what I am saying, does not match what you are thinking or what is acceptable in general. It urges one to be on defensive instead of being equal.
The automatic response to those words should be....NO, because it was just said it and if one oppose it then give ones own arguments. Then the conversation is equal again.
The NO in my answer was here also a direct reply to you question, accompanied by manual extract on that subject.
I am the last person to say that I all kown everything and I am eager to learn more.
Sob
Sat Jan 15, 2022 11:52 pm
That interview certainly makes a lasting impression. :lol: But it's under completely different circumstances. Here we have nice friendly technical forum, and there's no reason whatsover to assume that someone is here to get you. Except maybe @anav, one needs to be careful around him, but even that's just fun. :)
msatter
Sun Jan 16, 2022 12:04 am
Yeah Anav, as long he is on the other side of the ocean I feel safe. ;-)
I have no hard feeling towards Sindy....or in that case, Anav. I hope that is still mutual.
sindy
Sun Jan 16, 2022 12:39 am
To me, there is a difference between "Are you saying?" and "So what you are saying is:", but maybe that difference is not big enough to change the perception. Mental note made.
But we've gotten too far from the technical topic. The mechanism triggering the retry of the query using TCP does not depend on EDNS. EDNS is just a way to tell the server that the querier is ready to accept responses larger than the 512 bytes maximum specified by RFC 1035, by indicating a higher limit. The retry on TCP is always triggered by receiving a response with the TC (truncated) bit set.
Also, as @Sob wrote already, the UDP query being forwarded from unbound to a remote server is just another UDP packet to the Mikrotik, so if the whole chain works with Friztbox in place of Mikrotik, there must be a difference in handling of large UDP packets between Mikrotik and Frizbox, that's why I concentrate on looking how to fix that difference rather than suggesting how to overcome it specifically for DNS traffic. Because it may affect also other traffic than the UDP one - as was the case where I've seen it before.
bolsblue
Sun Jan 16, 2022 1:50 am
Thanks a lot for your replies!
Regarding the EDNS buffer size, this is already the default in unbound. I even set it as low as 512, and it's still not working...
So would that mean there is actually a TCP problem here? Do I have to add a firewall rule?
I haven't touched the MTU sizes on any of my devices or the MikroTik, so its all on 1500 default.
Sorry, I'm everything but a network expert, I actualy bought the MT to learn a bit about it ;)
sindy
Sun Jan 16, 2022 8:43 am
One of the great features of Mikrotik when it comes to learning about networking (but of course also for analysis of problems encountered) is that it can sniff the network traffic. So open a command line window (by pressing the [New Terminal] window in Winbox), make it as wide as your screen allows, run /tool sniffer quick ip-address=ip.of.dns.server port=53 in it, and make unbound send the problematic query to that server.
You will see immediately on the screen the UDP query packet "bubbling through the router", and you should also see the UDP response packet bubbling back. If you can see a subsequent TCP packet from unbound to the server, it means that the retry on TCP has been triggered properly. If you can only see it at the interface facing the unbound but not at your WAN interface, it means that your firewall rules have prevented it from being delivered to the server.
If there is no TCP retry, you'll have to set /tool sniffer set file-name=unbound.pcap, repeat the procedure above, download the file unbound.pcap, open it using Wireshark, and look into the DNS response for the value of the TC (truncated) flag.
bolsblue
Sun Jan 16, 2022 1:17 pm
So I did try the packet sniffer as you adviced, filtering for the unbound IP and port 53, and also on the pppoe interface, filtering for port 53.
In both cases I do see the UDP requests from unbound, going to the DNS root servers, trying all of them, but there never is any answer back... neither UDP nor TCP.
So is there actually a firewall rule preventing the answers? I only have the standard rules there...
I'm confused...
sindy
Sun Jan 16, 2022 1:23 pm
Can you see any responses if you send other queries, for which the responses are small enough?
If not, are your NAT rules correct, i.e. do the queries leave via the PPPoE interface with the IP address attached to that interface as their source one?
As usually, better post the export of the configuration as per the hint in my automatic signature below.
bolsblue
Sun Jan 16, 2022 1:37 pm
Yes, setting the DNS server in pi-hole to 1.1.1.1 e.g. there are UDP requests and resposes, that's working without problem.
# jan/16/2022 12:25:33 by RouterOS 6.49.2
# software id = QFBI-B40J
# model = RB760iGS
# serial number = xxx
add mtu=1500 name=LAN
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 max-mru=1492 max-mtu=\
    1492 name=pppoe-out1 user=xxxx
add name=listLAN
add name=WAN
add bridge=LAN interface=ether2
add bridge=LAN interface=ether3
add bridge=LAN interface=ether4
add bridge=LAN interface=ether5
add bridge=LAN interface=sfp1
set discover-interface-list=listLAN
add interface=LAN list=listLAN
add interface=LAN list=WAN
add address=203.0.113.1/24 interface=LAN network=203.0.113.0
/ip dhcp-client
add interface=ether1
set servers=203.0.113.40
add action=accept chain=input comment="accept established,related" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=pppoe-out1 \
    protocol=icmp
add action=drop chain=input comment="block everything else" in-interface=\
    pppoe-out1
add action=fasttrack-connection chain=forward comment=\
    "fast-track for established,related" connection-state=established,related
add action=accept chain=forward comment="accept established,related" \
add action=drop chain=forward comment="drop invalid" connection-state=invalid
    "drop access to clients behind NAT form WAN" connection-nat-state=!dstnat \
    connection-state=new in-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set winbox address=203.0.113.0/24
/ip ssh
set strong-crypto=yes
/system clock
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listLAN
/tool mac-server mac-winbox
And yes, my internal network is 203.0.113.0/24. I once set it that way for highest VPN compatibility ;)
sindy
Sun Jan 16, 2022 2:46 pm
What is the size of the query packets that don't get responded? A problem with PPPoE's MTU is the last idea I've got for now. There may be something about the contents of the queries, but I cannot see why it should differ depending on whether the query is sent via Fritzbox or via Mikrotik. Mikrotik doesn't redirect the queries, and they cannot evade the masquerade rule.
So if the responses don't fit into the PPPoE MTU, it means that all the servers send larger ones than 512 bytes and do not respect the edns-buffer-size value.
And the difference between Fritzbox and Mikrotik may be in how they treat PPPoE. I'm not an expert here, look through the forum for people with more experience in this (MTU of PPPoE interface being lower than the 1500 commonly used on Ethernet interfaces, and ways to work that around).
bolsblue
Sun Jan 16, 2022 3:33 pm
Thanks a lot for your help so far.
I already tried different MTU/MRU/MRRU sizes for the pppoe interface without success.
I think I’m going to try it without pppoe and use a double NAT with my Fritzbox being another router in the network.
Right now the Fritzbox is only a modem, which requires some kind of a hacky workaround, so maybe thats the issue…
sindy
Sun Jan 16, 2022 3:43 pm
What I'd definitely try would be to sniff at the unbound host while Mikrotik is out of the path, using tcpdump or Wireshark diretctly, to visualize using Wireshark how the queries and responses look like, i.e. whether the edns-buffer-size field is indeed present in the queries and whether the responses come complete (and therefore fragmented) despite that.
bolsblue
Sun Jan 16, 2022 4:16 pm
Ok, so I just connected the MT directly to the Fritzbox without PPPoE and everything is working. There seems to be a problem with the PPPoE connection.
So it's nothing with the MT. Guess I have to take a look into this or get another router.
Anyway, thanks for the assistance!
msatter
Sun Jan 16, 2022 4:31 pm
Can you set, or do you have your Fritz!box into Bridge mode as it is done when you setup the PPPoE from the Mikrotik?
bolsblue
Sun Jan 16, 2022 4:43 pm
Unfortunately you can't set the newer models into bridge mode. You can however allow other network devices to connect to the internet via PPPoE.
As my ISP only allows one connection, I didn't enter any login details into the Fritzbox, so it only synchronizes the DSL connection, and the MT actually connects to the internet via PPPoE.
However this is not intended by the manufacturer and can only be considered a hack I think, and I guess thats the reason the PPPoE connection has these problems with the larger UDP packets, as the DNS responses never actually arrive at the PPPoE interface.
msatter
Sun Jan 16, 2022 5:05 pm
If you can connect on the PPPoE in then that confirms that the Fritz does not have the PPPoE active and it should work.
What is the ping size you can get over the PPPoE with the don-not fragment flag active the Terminal of the Mikrotik?
ping 1.1.1.1 do-not-fragment size=1492 interface=pppoe-out
If to large then reduce size and till it fits. And your PPPoE can have a different name than pppoe-out.
bolsblue
Sun Jan 16, 2022 5:28 pm
I did the ping test some days ago when I experimented with MTU sizes.
I can set MTU on PPPoE to 1492, which would be standard on DSL I think, and it's the same size my Fritzbox uses when it's acting as a router.
I could ping up to 1492 without fragmentation (if I remember correctly). I also tested that from the pi-hole and it worked on both the MT and the Fritzbox up to the same size.
So there's no difference...
sindy
Sun Jan 16, 2022 6:07 pm
No matter how it is called in the configuration, if you can connect a PPPoE client device to the LAN port of the Fritzbox and it can talk to the PPPoE server accessible via the WAN of the Fritzbox, the Fritzbox does bridge the packets. So it is a bridge mode, and the fact that it is enabled by mere absence of PPPoE client settings on the Friztbox itself is just a kind of red herring. It doesn't seem like an accidental behaviour to me.
To the MTU issue - in order to be transported using PPPoE, the payload packet is encapsulated into PPP, which adds 8 bytes of additional headers to it. And if the maximum frame size supported on an Ethernet interface is 1514 bytes, which allows the payload of an Ethernet frame to be 1500 byte large, it means that if the Ethernet payload is the PPP-encapsulated IP packet, the available size for the IP payload is just 1492 bytes. And with Mikrotik, there is one more caveat - it actually adds 20 bytes of PPP headers, or at least saves space for them, so it can only squeeze 1480-byte IP packets into a 1514-byte Ethernet frame.
From there, there are two escape paths - either you have to extend the maximum size of the Ethernet frame to 1534 bytes (or even 1538 bytes if you'd want to squeeze in a VLAN tag), or you can use MLPPP to let PPP split the payload packets into multiple smaller transport ones and reassemble them at the other end of the PPPoE tunnel. Both approaches require that both the PPPoE client and the PPPoE server support them, and in case of the former one, an additional limit may be the maximum frame size at the LAN interface of Fritzbox.
So if you've tried to set mrru to 1500 or more and it didn't help, chances are high that your ISP does not support MLPPP. So now you can try to set the mtu of ether1 to 1520 - for some reason, the pppoe client doesn't look at l2mtu (Ethernet frame size) but at mtu (normally, IP packet size) when determining the size of the transport packets. And see whether that works with Fritzbox in "unadmitted bridge mode".
bolsblue
Mon Jan 17, 2022 12:57 am
Thanks for the clarification on MTU sizes.
I tried setting the ether1 MTU to 1520 but that didn't change anything. The AVM knowledge base says that Fritzboxes have a miximum frame size of 1518, so this wouldn't work anyways I think.
Seems like I'm out of luck here. Maybe I'll buy a dedicated bridge modem to see if that works.
sindy
Mon Jan 17, 2022 8:46 am
First try it the other way round, set max-mtu and max-mru at the /interface pppoe-client to 1480 rather than 1492, leaving the MTU at the underlying ether1 at 1500.
bolsblue
Mon Jan 17, 2022 9:17 am
Did that too, still nothing…
sindy
Mon Jan 17, 2022 9:22 am
When set up like this, what does /interface pppoe-client monitor 0 once show?
msatter
Mon Jan 17, 2022 12:25 pm
I have the expierence that ehat RouterOS does not reflect reality.
Tried yesterday several settings and despite it was stated 1492 I only get 1430 without fragmenting. I have ping running when changing to check reality.
It will take a moment before ping uses the new settings.
I have a 4011 that have standard problems when using a SFP and PPPoE.
bolsblue
Wed Jan 19, 2022 11:24 pm
          status: connected
          uptime: 11m33s
    active-links: 1
        encoding:
    service-name:
         ac-name: SWBJ00
          ac-mac: CC:CE:1E:F4:AE:6E
             mtu: 1480
             mru: 1480
   local-address: XX.XX.XX.XX
  remote-address:XX.XX.XX.XX
I tried sniffing again with an already running unbound and trie to create some DNS traffic, and looked at the sizes of the packets, the highest I saw was 1345.
I don't know if that's helping at all, but I feel this has something to do with the Fritzbox.
bolsblue
Wed Jan 26, 2022 1:26 pm
Okay, so I can now say for sure that it's something with the Fritzbox.
I got my hands on a dedicated bridge modem and that's working flawlessley, with a MTU of 1492.
I don't know what exactly is up with the Fritzbox, but I don't think there is anything I can do about it, as there are no settings that could be changed on it.
Anyways, just wanted to let you know.
exel90
Re: DNSSEC Problems (large UDP packets)  [SOLVED]
Mon Apr 11, 2022 2:27 pm
Hi bolsblue,
i had the same problem for at least 3 days and after troubleshooting for almost 20 hours beginning at docker container level, I also found the problem at the AVM Fritzbox in PPPOE Mode.
The solution for the problem is described in the two links:
https://ubiquiti-networks-forum.de/wiki ... betreiben/
https://blackdown.de/articles/tag/pppoe/
That fix the problem immediately and everything works like a charm.
bolsblue
Sat Apr 30, 2022 12:12 am
Wow that's a great find. I do use another modem now, but thanks a lot for sharing!
Users browsing this forum: GoogleOther [Bot], kormenator and 178 guests
