I'm trying to send a WoL packet to Mikrotik router over WAN. Mikrotik router is configured to forward the received packet to a PC and wake it up.
Testing this on LAN works, but not over WAN.
I enabled VPN access on Mikrotik and configured a VPN connection on my cellphone. VPN connection is successfully established using as Server Address the private IP that Mikrotik has from Modem's DHCP. So, locally, everything's fine.
How can I do the same thing over WAN?
Do I have to connect from my cellphone to the VPN address provided by Mikrotik and enter the Mikrotik's VPN credentials so I would virtually be in the same LAN with the router?
Eventually what is the role of the VPN address *********.sn.mynetname.netprovided by Mikrotik?
In the PPP --> Profiles there is a default-encryption entry that has a local IP of 192.168.89.1. In what network does this IP apply?
