woodych
RouterOS 7.1: Multicast PIM SM configuration - HowTo?
Sun Jan 16, 2022 9:43 am
Dear Community
It looks as my previous post was lost then MikroTik had a server outage a couple of weeks ago.
After upgrading from RouterOS 6 to RouterOS 7.1 my multicast PIM Routing config was gone. That part is all now, NP!
But whatever I do when I try to add a BSR or PR candidate. I get presented the Error: Couldn't add New PIM Candidate - address interface must be specified (6)
Whatever I specify as address, is not being accepted. Not via WebGUI nor via CLI.
Wiki is outdated and only covers RouterOs 6 PIM. Has anyone managed to get PIM SM to work on RouterOS 7?
Edit: I think there is a serious bug in PIM SM.
After adding an instance and then adding an interface template, the instance disappears and the WebGUI behave strangely.
So I went to the CLI and tried:
/routing/pimsm/instance/add name=pimsm1 vrf=main
/routing/pimsm/instance/print
=> Mikrotik hangs!
=> Mikrotik looses default route!
=> Manual Reboot. Operation restored, but pimsm1 instance disappeard again.
-Benoît-
Liv
Re: RouterOS 7.1: Multicast PIM SM configuration - HowTo?
Thu Feb 17, 2022 7:18 pm
my Pim routing config is gone as well when upgraded to 7.1.1,
did you find a fix?
woodych
Sun Jun 12, 2022 8:51 am
Unfortunately not yet. But if you search the forum form "pimsm" you will find many issue mentioned with V7 and nobody confirming it works :-)
Release Notes for 7.4rc seem to indicate a fix coming. A user wrote pimsm started to work on this version. But I an not going to test 7.4rc on my main router. I'll wait for the propper release.
netravnen
Thu Oct 19, 2023 1:22 pm
