Niksi
VPN Connection
Tue Jan 18, 2022 8:18 am
I have 2 router and they ar connected with VPN (L2TP connection, Server and User)
1st router - 10.0.10.0/24
2st router - 192.168.12.0/24
When I am run tracert 192.168.12.1 from server, it goes outside of VPN and if IP is 192.168.3.1, it works correctly (see attached)
I can't understand what's wrong.
P.s 192.168.3.0/24 is also connected with VPN at same router.
MickeyT
Re: VPN Connection
Tue Jan 18, 2022 9:05 am
Please export and attach the configurations for both units so that we can see the exact setup you are using (I've assumed they are both MikroTik units).
On router 1: /export hide-sensitive file=Router1
and
On router 2: /export hide-sensitive file=Router2
Niksi
Re: VPN Connection
Tue Jan 18, 2022 10:38 am
and
Is not possible without this? I don't want to share my config file in public
nichky
Re: VPN Connection
Tue Jan 18, 2022 11:21 am
if you don't want to shear, then you shouldn't expect answer. Do we know what you have conf?
Niksi
Re: VPN Connection
Tue Jan 18, 2022 3:14 pm
I can send someone privately.
p.s if I will share as public am I secured from unauthorized access?
own3r1138
Long time Member
Long time Member
Re: VPN Connection
Tue Jan 18, 2022 3:20 pm
@Niksi
you should check your export file and replace your Public IPs, DDNS, Private Key. IPsec Secret, Custom ports.
Then yes you are secure.
use notpad+ for EZ replacement in all lines.
Users browsing this forum: A1Digital, oliverlexis, zekino and 78 guests
