frika
Does Mikrotik support Openvpn sha2?
Tue Jan 18, 2022 12:21 pm
A simple question... I am trying to set up an openvpn but all the openvpns i can find support sha256/512. It seems that because of its vulnerability sha1 is avoided/not used anymore and if Mikrotik can't support sha256/512 then openvpn is simply not an option for me. Can anyone help? Thank you in advance.
Sob
Re: Does Mikrotik support Openvpn sha2?  [SOLVED]
Tue Jan 18, 2022 7:20 pm
Unfortunately for you and many others, MikroTik's support for OpenVPN was always lacking and continues to do so.
Edit: 7.2rc1 has sha256 and sha512, but so far only in CLI, not in WinBox.
own3r1138
Long time Member
Long time Member
Tue Jan 18, 2022 7:43 pm
I think it's just added the SHA256 CBC 256, But it's beta?
Sob
Tue Jan 18, 2022 7:50 pm
Whole v7 is beta, only it's not officially called that. ;)
own3r1138
Long time Member
Long time Member
Tue Jan 18, 2022 7:54 pm
I kinda Figure this out and have a lot of problems with OVPN on 7.1.1 +
But other than that for simple usage, it's pretty much stable, But not optimized
frika
Wed Jan 19, 2022 9:10 am
Thanks for all the replies guys I appreciate your help. I hope you have a good day/evening.
Users browsing this forum: Amazon [Bot], Bing [Bot], GoogleOther [Bot], patrikg and 113 guests
