Kentzo
Sniffing 802.11 frames
Thu Jan 20, 2022 8:42 pm
I would like to sniff 802.11 frames as they ingress/egress the wlan interface in order to diagnose whether the packets set 802.11 UP.
The Packet Sniffer tool captures ethernet frames. The Wireless Sniffer disables interface, causing all clients to disconnect, and captures all air traffic it hears.
Is there an option to sniff actually received / sent 802.11 packets for a wlan connected client?
Syntax highlighting and completions for the Mikrotik scripting language in Sublime Text.
Available via Package Control.
r00t
Long time Member
Long time Member
Re: Sniffing 802.11 frames  [SOLVED]
Fri Jan 21, 2022 6:13 pm
no, that's currently not possible with Mikrotik ROS.
As you have found, running sniffer disables the interface for regular use, so it's not possible to run it together with regular AP or client.
You would have to use second radio to make this work with Mikrotik.
anav
Fri Jan 21, 2022 11:41 pm
Its the WEEKEND, time for my silly post......
Kentzo, word, you cannot get high sniffing frames. ;-)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: Ahrefs [Bot] and 11 guests
