DelphinusPT
DHCP don't give IP after quick disconnect
Tue Jan 25, 2022 8:29 pm
I just installed a CRS309-1G-8S+IN and I use it to route the trafic from my provider to my lan and also use it has DHCP server for each of my Vlans.
My problem is that if I connect to the wifi SSID1 and disconnect and try to reconnect it won't give IP, if I wait or connect to SSID2 and return to SSID1 it works.
I test with add-arp for vlan103 and seems better but not 100% sure it's fixed.
my config
add address-pool=Vlan1_dhcp_pool interface=bridge lease-time=3h name=DHCP_Vlan1
add add-arp=yes address-pool=Vlan103_dhcp_pool interface=vlan103 lease-time=3d \
name=DHCP_Vlan103
I have many wifi smarthome devices and need to put each in it's vlan and to config them the procedure is connected to my home wifi than connect to the wifi of the device and return to my home wifi, before when the DHCP was in my AP's I never have problems now it takes a lot of time to give IP and the smarthome application timeout.
Can someone help me? Thanks
Users browsing this forum: ShindigNZ and 66 guests
