mazinsaeed
Script for down & up interfaces
Wed Jan 26, 2022 7:47 am
Hi , I want to do a script if interface sfp-sfpplus1 down , enable ether10 and vice versa
My main interface is sfp-sfpplus1 and the backup interface is ether10 , the ( sfp-sfpplus1 coming from fiber optic and ether10 is a backup line from same service provider )
ether10 is disabled and the service is up from sfp-sfpplus1
So I want to do a script if interface sfp-sfpplus1 down , enable ether10 & if sfp-sfpplus1 is up back disable ether10
sfp-sfpplus1 & ether10 are in same bridge1
Best Regards
Jotne
Re: Script for down & up interfaces
Wed Jan 26, 2022 8:25 am
Here you go:
Disable sfp-sfpplus1, enable ether10
/interface/ethernet/disable [find where name=sfp-sfpplus1]
/interface/ethernet/enable [find where name=ether10]
Disable ether10, enable sfp-sfpplus1
/interface/ethernet/disable [find where name=ether10]
/interface/ethernet/enable [find where name=sfp-sfpplus1]
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
mazinsaeed
Thu Jan 27, 2022 7:26 am
Here you go:
Hi , both of them have same code ???
Jotne
Thu Jan 27, 2022 8:20 am
Fixed in above post.
MikroTik->Splunk
mazinsaeed
Thu Jan 27, 2022 10:06 am
is it working like Sisco switch as Add Ethernet Flex I/O ?
when spf interface down , enabling ether10 and vice versa ??
Jotne
Thu Jan 27, 2022 12:43 pm
Not sure what you mean.
What I posted was a manual change.
Do you like a script that automatically change port? Try Netwatch
MikroTik->Splunk
Users browsing this forum: No registered users and 5 guests
