dominiaz
RB4011 + Compex WLEV2-20 = issues
Wed Jan 26, 2022 3:21 pm
I have RB4011 (WIFI version).
I tried to change Mikrotik R11E card to Compex WLE1216V2-20, but that card wont work - I need 2.4Ghz with wifiwave2 package.
Compex card isnt even detected in Resources/IRQ. R11E card normal working in that RB4011. Compex card is normally recognizable by PC so its OK.
I have RouterOS 7.1.1 with wifiwave2 package.
Do you have any ideas how to run Compex WLE1216V2-20 on RB4011?
mkx
Re: RB4011 + Compex WLEV2-20 = issues
Wed Jan 26, 2022 6:52 pm
Is the card listed in /system resource pci?
BR,
Metod
dominiaz
Wed Jan 26, 2022 7:13 pm
No.
mkx
Wed Jan 26, 2022 7:21 pm
No.
That's a very bad sign. Entries there are created by PCI subsystem driver and any hardware properly functioning should appear there even if ROS doesn't have driver for it.
Try to re-seat the card in the miniPCIe slot and make sure it doesn't move afterwards (e.g. when you're fastening the screws).
BR,
Metod
dominiaz
Wed Jan 26, 2022 7:39 pm
No.
i tried 3 times to re-seat card in rb4011. When I put card to PC then it works normal.
almeiras
Thu Jan 27, 2022 10:54 am
Hi! Does the card touch any components of the board? The original mPCIe socket is not so tall, so the board may short-circuit something.
One more thing: do you have any link to the manufacturer's page? I can't find anything about that chip. EDIT: I found it, I got the very same card. Same thing. But in my case, I made it work in a RBM33G flashed with OpenWRT.
dominiaz
Sat Jan 29, 2022 6:24 am
The card doesn`t touch any components. It is fitted ok.
Do you have any other advises?
Users browsing this forum: Ahrefs [Bot] and 12 guests
