raki
Check for Updates failed - could not resolve dns name
Wed Jan 26, 2022 11:13 pm
I would like to ask you for help with home network issue.
My network is described at attached picture. Router A is providing connection to the Internet.
Problem is that I can't update the RouterOS on the Router B. Error message is "could not resolve dns names". Updates on Router A and C are working fine. I see different DNS setup on Router B versus C but I don't know how to force same DNS configuration with dynamic servers to Router B. I don't even know if this is the solution.
It's the only problem. The other devices behind the Router B are web sites correctly (there is no problem with DNS).
Router B DNS configuration:
Router C DNS configuration:
Thanks in advance,
Peter
Sob
Re: Check for Updates failed - could not resolve dns name
Thu Jan 27, 2022 2:18 am
As a quick test, add 8.8.8.8 as static dns server on router B.
Come on people, do you really have to quote full posts? It's annoying and in most cases useless.
raki
Thu Jan 27, 2022 9:47 am
Thanks for recommendation. I tried it but still not working.
erlinden
Thu Jan 27, 2022 10:00 am
Would love to see configurations of all devices (/export hide-sensitive file=anynameyoulike)
You can upgrade by placing the correct package on the device. That won't solve your DNS problem, but will upgrade the device.
First the problem, then the solution
anav
Thu Jan 27, 2022 2:04 pm
HI erlinden not 100% positive but I think in vers 7, the hide-sensitive doesnt do anything (or more accurately is not required) ........ read that somewhere....
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
holvoetn
Thu Jan 27, 2022 2:18 pm
hide-sensitive is default now and it makes sense to have it like that.
If you want to see all, you need to use show-sensitive or even verbose (have to test if that last one is not redundant ).
But it doesn't hurt to specify it since it's not always obvious which version a user has (ROS6 or 7).
raki
Thu Jan 27, 2022 7:43 pm
Router A
# jan/27/2022 18:36:21 by RouterOS 6.49.2
# software id = 42LP-PZFZ
# model = 960PGS
# serial number = AD8A0AD5C431
add name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full disabled=yes
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.11.100-192.168.11.254
add address-pool=dhcp disabled=no interface=bridge1 lease-time=2h name=dhcp1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge1 interface=sfp1
/interface bridge port-extender
# no hw support
set control-ports=ether4 switch=switch1
add interface=ether1 list=WAN
add address=192.168.11.1/24 interface=ether2 network=192.168.11.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.11.0/24 dns-server=195.39.77.66,8.8.8.8 gateway=\
    192.168.11.1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.11.253
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Prague
/system identity
set name="MikroTik master"
/tool graphing resource
add
/tool sniffer
set filter-interface=ether4 only-headers=yes
Router B
# jan/27/2022 18:38:46 by RouterOS 6.48.1
# software id = V2ZC-74WQ
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A770946EBA1
add admin-mac=B8:69:F4:36:15:D5 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="czech republic" distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=Raki-Trebo-2 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=Raki-Trebo-2 \
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm \
    group-encryption=aes-ccm name=security
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
    unicast-ciphers=tkip,aes-ccm
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=ether2 name=defconf
/user group
/caps-man manager
set enabled=yes
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridge interfaces=wlan2,wlan1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=185.140.244.62,8.8.8.8
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add distance=1 gateway=192.168.11.1
/system identity
set name="MikroTik Wifi Obyvak"
/tool mac-server
/tool mac-server mac-winbox
Router C
# jan/27/2022 18:39:42 by RouterOS 6.49.2
# software id = W3SA-PWMP
# model = RB951G-2HnD
# serial number = DE350DE38DD8
add admin-mac=08:55:31:EF:3A:DE auto-mac=no comment=defconf name=bridge
/interface wireless
    country="czech republic" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=Raki-Trebo-Wrk-2 \
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
add name=dhcp ranges=192.168.99.10-192.168.99.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
set discover-interface-list=all
set bridge=bridge interfaces=wlan1
add address=192.168.99.1/24 comment=defconf interface=ether2 network=\
    192.168.99.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf disabled=no interface=ether1
add address=192.168.99.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
    192.168.99.1 netmask=24
/ip dns static
add address=192.168.99.1 comment=defconf name=router.lan
/system clock
/system identity
set name="MikroTik Wifi Pracovna"
Sob
Thu Jan 27, 2022 8:20 pm
That's weird config. On B and C you have *all* ports bridged, and on bridge you have at the same time both dhcp client and dhcp server with different subnets. So you have one big network segment with three dhcp server competing against each other. If you want separate subnets, ether1 should be separate (not member of bridge) and dhcp client should be on ether1.
raki
Thu Jan 27, 2022 9:39 pm
It's my home network so I rather want one big network where each segment can acces others (PC to NAS). What to do in this case, please?
Sob
Thu Jan 27, 2022 11:31 pm
You need to decide how exactly it should work. You can have one big common subnet for everything, and then all ports bridged on B and C would be ok (they would be completely transparent, same way as switch). Or you can have different subnets with no access restrictions, but there will always be some, because those will be different L2 segments, so e.g. some protocols for automatic discovery of devices won't work. What you have now is some weird hybrid with not clearly defined behaviour.
raki
Thu Jan 27, 2022 11:58 pm
I would be happy with one big subnet were all devices transparently see each other.
Sob
Re: Check for Updates failed - could not resolve dns name  [SOLVED]
Fri Jan 28, 2022 3:00 am
You're almost there. Basically just disable dhcp servers on B and C, and you'll have one big network with 192.168.11.0/24.
Other details:
- on both B and C, dhcp client should be on bridge (and you need to enable the one on B, that's why it doesn't work now!)
- bridge should be added to LAN interface list
- addresses 192.168.88.1/24 and 192.168.99.1/24 won't be needed anymore, there will be 192.168.11.x from dhcp (you can add static reservations on A)
- it's not clear to me, how you're currently connecting to B, when both firewall and mac winbox allow access only from interfaces in LAN list, but since you have all interfaces in bridge and bridge itself is not listed, it shouldn't work
- it's good idea to add some firewall on A, because as it is now, it's wide open to whole world (that's if you have public address, otherwise it's slightly less bad); you can find some inspiration in this thread
raki
Fri Jan 28, 2022 4:27 pm
Other details:
Thank you for this. I'm a bit smarter again, although I'm not sure how to configure the firewall good enoug for my network. I applied some rules (on Router A) described in post you mentioned and below is current configuration of A. I would be very grateful for any further recommendations but thank you also for the ones so far. Besides, the original problem with DNS and the RouterOS upgrade is solved.
# jan/28/2022 15:20:48 by RouterOS 6.49.2
# model = 960PGS
add name=bridge1
add name=WAN
add name=LAN
/user group
# no hw support
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.11.228 client-id=1:0:11:32:70:a1:cb mac-address=\
    00:11:32:70:A1:CB server=dhcp1
add address=192.168.11.151 client-id=1:4c:cc:6a:5:ac:c7 mac-address=\
    4C:CC:6A:05:AC:C7 server=dhcp1
add address=192.168.11.2 client-id=1:b8:69:f4:36:15:d5 mac-address=\
    B8:69:F4:36:15:D5 server=dhcp1
add address=192.168.11.3 client-id=1:8:55:31:ef:3a:de mac-address=\
    08:55:31:EF:3A:DE server=dhcp1
add address=192.168.11.135 client-id=1:b2:fd:6:30:c5:4d mac-address=\
    B2:FD:06:30:C5:4D server=dhcp1
add address=192.168.11.140 client-id=1:38:f3:ab:6a:10:12 mac-address=\
    38:F3:AB:6A:10:12 server=dhcp1
    192.168.11.1
    invalid
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
add action=accept chain=forward comment="allow internet traffic" \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
    connection-nat-state=dstnat
add action=drop chain=forward
/ip service
/system clock
/system identity
add
/tool sniffer
Sob
Fri Jan 28, 2022 5:04 pm
Firewall is already nice and safe, all incoming connections from internet are blocked and access is allowed only from LAN. If you'd want to have e.g. VPN server to get into LAN from remote networks, you'd add rule(s) to allow it in chain=input before the last drop rule (plus config for VPN server of course). If you don't need anything like that, then it's fine as it is.
And you don't need these:
The new masquerade rule you added is better. And the route is not needed anymore, if you have only single subnet.
raki
Fri Jan 28, 2022 5:20 pm
Sob, thanks!
Users browsing this forum: Baidu [Spider] and 15 guests
