Hi.
I am running a hAP ac³ as my Edge Router. It works fine for my personal setup.
Now I have to integrate 4 Servers into my setup.
Each Server has two Ethernet Connections: a regular one and a remote console port.
So I added two unmanaged 5-Port-Switches, each switch directly connected to the hAP ac³.
One switch for the service ports, and another one for the regular ports.
So far so good.
I expected it to work immediately, because there's not much magic happening. Right? each device just needs to get an IP address from my ac³ for now for being reachable.
However, at the moment there is only one service port reachable and two regular interfaces.
In the Switch -> Host menu of the ac³ I can see all the mac addresses. Good.
In the IP menu, DHCP Server submenu -> Leases I can only see the three mentioned devices. Not good.
Why is that? I have no clue why this is happening.
Thank you.
