I've upgraded to RouterOS 7.1.1 for the support of Large BGP communities. The following has been configured, but it is not received by the upstream provider:
Code: Select all
/routing bgp connection
add address-families=ip,ipv6 as=[My-AS] connect=yes disabled=no listen=yes \
local.role=ebgp name=peer2 output.filter-chain=BGP-OUT-HEP3 .network=\
bgp-networks remote.address=[IPv6 peer address]/128 .as=[ISP-AS] \
routing-table=main templates=default
/routing filter rule
add chain=BGP-OUT-HEP3 disabled=no rule=\
"if ( dst == [IPv6 Subnet]/48 ) { accept; }"
"append bgp-large-communities [ISP-AS]:6939:3; accept;"
I've already recreated and restarted the filter. Also restarted the BGP connection. But it did nothing unfortunately.
Is there someone who has more information about ROSv7 Large BGP communities?
