TedRule
Lack of Static Route functionality in v7 WebFig
Thu Jan 27, 2022 6:10 pm
Having updated one of my RB2011's from v6.49 to v7.1.1, I see that v7 WebFig doesn't appear to display the current routing table at all under the IP/Routes/Routes tab.
"/ip/route/print" and "/ipv6/route/print" display more or less what I would expect on the CLI ( other than unreachable routes which is a separate issue TBD ).
The GUI allows me to attempt to create an IPv4 route, bringing up the relevant form, but once I try to Save it complains with:
"Couldn't add New Route - feature is not implemented (2)"
FWIW, there is no BGP or OSPF or RIP running/configured on the device.
Is this lack of functionality a known issue?
Sob
Re: Lack of Static Route functionality in v7 WebFig
Thu Jan 27, 2022 6:22 pm
Yes, it seems a bit broken. I can add new route, but listing shows only a few, not all, and then there's error in browser's console:
master-min-d33198cb97c3.js:820
Uncaught TypeError: Cannot read properties of null (reading 'getObject')
    at C.enm.dynamic.toString (master-min-d33198cb97c3.js:820:46)
    at enum2string (master-min-d33198cb97c3.js:190:81)
    at C.types.addr.less (master-min-d33198cb97c3.js:647:35)
    at CmpAscending.cmp (master-min-d33198cb97c3.js:1039:337)
    at master-min-d33198cb97c3.js:1095:93
    at binarySearch (master-min-d33198cb97c3.js:366:121)
    at Table.insertRow (master-min-d33198cb97c3.js:1095:34)
    at Table.updateRow (master-min-d33198cb97c3.js:1106:212)
    at Array.Table.lstn (master-min-d33198cb97c3.js:1042:507)
    at Listeners.notify (master-min-d33198cb97c3.js:309:100)
Users browsing this forum: uxertxo and 70 guests
