multissid
How to script "Home" ssid updated to "Office" ssid as time-event or GPS event ?
Sat Jan 29, 2022 1:02 am
Let me know if ssid name can be scripted to update from Home to Office as time event, controlled by
office hours or by GPS geolocation for a mobile AP by Mikrotik ?
Jotne
Re: How to script "Home" ssid updated to "Office" ssid as time-event or GPS event ?
Sat Jan 29, 2022 12:13 pm
SSID can easily be change by a scrip scheduled at fixed time.
Not sure how to do it by GPS location,.
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
multissid
Sun Jan 30, 2022 12:04 am
thank you my dear friend for your kind reply.
My friend offers me used AP/router by Mikrotik to be collected next week
So I am working hard to learn if features sought are supported.
I previewed a number of scripts published at forum
and there is none for "ssid: set/ enable/ disable
The only script for wireless interface is the following
I assume "Guest" stays for a specified "ssid"
So I need to learn how to set a new ssid via script
and more to have "Home" ssid switched to "Office" ssid at a specified time
resembling cron jobs
Cron Job: a Comprehensive Guide for Beginners 2022
https://www.hostinger.com/tutorials/cron-job
Cron is a utility program that lets users input commands for scheduling tasks repeatedly at a specific time. Tasks scheduled in cron are called cron jobs. Users can determine what kind of task they want to automate and when it should be executed. Cron is a daemon …
:if ([/interface wireless get Guest disabled]=true) \
do={[/interface wireless enable Guest; /beep frequency=380 length=300ms;
:delay 300ms;
:beep frequency=380 length=300ms;
:delay 300ms;
:beep frequency=770 length=600ms;]} \
else={[/interface wireless disable Guest; beep frequency=770 length=300ms;
:delay 300ms;
:beep frequency=770 length=300ms;
:delay 300ms;
:beep frequency=380 length=600ms;]}
:delay 300ms;
:delay 300ms;
/system leds set [find where leds=user-led] type=on;]} \
/beep frequency=770 length=300ms;
:delay 300ms;
:delay 300ms;
/system leds set [find where leds=user-led] type=off;]}
Is there other repository for scripts of interest toi me ?
multissid
Sun Jan 30, 2022 12:20 am
follow up
from
Script for down & up interfaces
viewtopic.php?t=182621
Here you go:
Disable sfp-sfpplus1, enable ether10
Code: Select all
/interface/ethernet/disable [find where name=sfp-sfpplus1]
/interface/ethernet/enable [find where name=ether10]
Disable ether10, enable sfp-sfpplus1
/interface/ethernet/disable [find where name=ether10]
/interface/ethernet/enable [find where name=sfp-sfpplus1]
ok, I need to enable/ disable wireless interfaces
but how to script ?
new wireless interface called "HOME" "OFFICE (as ssid ) ?
DuMbh3aD
Fri Feb 11, 2022 4:00 pm
/system scheduler
add interval=1d name=HomeSSID on-event=\
    "/interface wireless set [ find default-name=wlan1 ] ssid=HOME" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=feb/11/2022 start-time=18:00:00
add interval=1d name=schedule1 on-event=\
    "/interface wireless set [ find default-name=wlan1 ] ssid=OFFICE" policy=\
    start-date=feb/11/2022 start-time=08:00:00
Users browsing this forum: No registered users and 5 guests
