have my Lora9 gateway connected via POE Ethernet to my home network on 192.168.1.176
The wAP Lora9 has its own wifi which I renamed to an SSID of SimonLora and I connect on 192.168.88.1 as per standard
But I would prefer to just use WiFi to both access the device and as the link to my home network for Internet access for the LoRa traffic back to TTN and not use Ethernet at all so I can mount the device outside my house. I don't want to run a 25 meter outdoor ethernet cable, why can't I just use the WiFi connection?
How do I change the wifi to no longer be an AP, but just another device on my network? I assume if I do this that WinBOX will then be able to access it on the 192.168.1.x network address?
Simon
