Duhhhh
Host PC static IP => RB5009UG+S+IN => 5 devices with same IP addresses. Help. How to?
Sat Jan 29, 2022 5:08 am
Hi all. I have general idea about networking and I ran into the problem that I need to solve.
Let's say we have device that have web UI accessible through ethernet, only with GChrome by entering https://192.168.255.129.
The PC must have static IP address 192.168.255.130 subnet 255.255.255.0 in ipv4 settings of the ethernet.
The problem, I need to connect, and have constant connection in multiple Chrome windows to 5 devices simultaneously, not one by one, not one after another, all 5 at the same time, in 5 different Chrome windows.
The IP of the device is not changeable, it should stay the same, it's preset by manufacturer. No, it can not be changed on the device itself.
What I would like to do is, to do the forwarding of each endividual ethernet port on my router RB5009UG+S+IN.
My pc on ether1.
Device 1 on ether2
Dev2 on ether3
Dev3 on ether4
And so on.
The idea is to make router adress to the right device with custom IP that I'll assign them with.
Let's say. Dev1 192.168.255.11
Dev2 192.168.255.12
Dev3 192.168.255.13
Etc.
So if I enter 192.168.255.12 in Chrome adress bar, the router knows that it needs to send this request to dev2 that is on ether2 on https://192.168.255.129. And then return the reply the same way back to that Chrome window.
I made a little config, please advise if it'll work. Or maybe you know better solution..
ip route vrf
add interfaces=ether2 routing-mark=DEV1
add interfaces=ether3 routing-mark=DEV2
add interfaces=ether4 routing-mark=DEV3
add interfaces=ether5 routing-mark=DEV4
add interfaces=ether6 routing-mark=DEV5
add address=192.168.255.1 interface=ether1 network=192.168.255.0
add address=192.168.255.3 interface=ether2 network=192.168.255.4
add address=192.168.255.3 interface=ether3 network=192.168.255.4
add address=192.168.255.3 interface=ether4 network=192.168.255.4
add address=192.168.255.3 interface=ether5 network=192.168.255.4
add address=192.168.255.3 interface=ether6 network=192.168.255.4
add address=192.168.255.11 interface=ether1 network=192.168.255.0
add address=192.168.255.12 interface=ether1 network=192.168.255.0
add address=192.168.255.13 interface=ether1 network=192.168.255.0
add address=192.168.255.14 interface=ether1 network=192.168.255.0
add address=192.168.255.15 interface=ether1 network=192.168.255.0
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=192.168.255.11 new-routing-mark=DEV1
add action=mark-routing chain=prerouting dst-address=192.168.255.12 new-routing-mark=DEV2
add action=mark-routing chain=prerouting dst-address=192.168.255.13 new-routing-mark=DEV3
add action=mark-routing chain=prerouting dst-address=192.168.255.14 new-routing-mark=DEV4
add action=mark-routing chain=prerouting dst-address=192.168.255.15 new-routing-mark=DEV5
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=192.168.255.130 new-routing-mark=main
add action=dst-nat chain=dstnat dst-address=192.168.255.11 in-interface=ether1 to-addresses=192.168.255.129
add action=src-nat chain=srcnat out-interface=ether2 to-addresses=192.168.255.3
add action=dst-nat chain=dstnat dst-address=192.168.255.12 in-interface=ether1 to-addresses=192.168.255.129
add action=src-nat chain=srcnat out-interface=ether3 to-addresses=192.168.255.3
add action=dst-nat chain=dstnat dst-address=192.168.255.13 in-interface=ether1 to-addresses=192.168.255.129
add action=src-nat chain=srcnat out-interface=ether4 to-addresses=192.168.255.3
add action=dst-nat chain=dstnat dst-address=192.168.255.14 in-interface=ether1 to-addresses=192.168.255.129
add action=src-nat chain=srcnat out-interface=ether5 to-addresses=192.168.255.3
add action=dst-nat chain=dstnat dst-address=192.168.255.15 in-interface=ether1 to-addresses=192.168.255.129
add action=src-nat chain=srcnat out-interface=ether6 to-addresses=192.168.255.3
Sob
Re: Host PC static IP => RB5009UG+S+IN => 5 devices with same IP addresses. Help. How to?
Sat Jan 29, 2022 8:51 pm
It looks like it should work. I did something similar here:
viewtopic.php?p=532709#p532709
And extended version that allowed also connections from those same-address devices:
viewtopic.php?p=639899#p639899
Come on people, do you really have to quote full posts? It's annoying and in most cases useless.
Duhhhh
Tue Feb 01, 2022 2:21 am
I have routeros7, and it's an issue for me, cause vrf been moved to different menu. And I really struggled to make it work. I showed this config to few other people and they said that it should work, but for some reason it doesn't. 🤕😪😭. I don't know what to do. Should,ve buy Cisco I guess.
Duhhhh
Tue Feb 01, 2022 5:07 am
This is what i need to achieve pretty much, no internet connection needed.
Sob
Tue Feb 01, 2022 5:39 am
Take your pick. With VRF:
/ip vrf
add name=DEV1 interfaces=ether2
add name=DEV2 interfaces=ether3
add interface=ether1 address=192.168.255.1/24
add interface=ether1 address=192.168.255.11/24
add interface=ether1 address=192.168.255.12/24
add interface=ether2 address=192.168.255.1/32 network=192.168.255.129
add interface=ether3 address=192.168.255.1/32 network=192.168.255.129
add dst-address=192.168.255.0/24 gateway=ether1 routing-table=DEV1
add dst-address=192.168.255.0/24 gateway=ether1 routing-table=DEV2
/ip firewall mangle
add chain=prerouting dst-address=192.168.255.11 action=mark-routing new-routing-mark=DEV1
add chain=prerouting dst-address=192.168.255.12 action=mark-routing new-routing-mark=DEV2
set [ find default-name=ether2 ] arp=proxy-arp
set [ find default-name=ether3 ] arp=proxy-arp
Without VRF:
/routing table
add name=DEV1 fib
add name=DEV2 fib
add dst-address=192.168.255.129/32 gateway=ether2 routing-table=DEV1
add dst-address=192.168.255.129/32 gateway=ether3 routing-table=DEV2
/ip firewall mangle
Duhhhh
Tue Feb 01, 2022 6:42 pm
/ip vrf
/ip firewall mangle
Without VRF:
/routing table
add name=DEV1 fib
add name=DEV2 fib
/ip firewall mangle
First thing, is not working. The packets for the device should come from 192.168.255.130/24 or at least it should think that it's coming from that ip.
I'll try second option without vrf.
Sob
Tue Feb 01, 2022 11:10 pm
What can I say, works here.
Duhhhh
Wed Feb 02, 2022 4:47 am
Second one also doesn't work, chrome shows me : this site can't be reached, 192.168.255.12 took too long to respond.
Sob
Wed Feb 02, 2022 11:39 am
You'll have to go a bit deeper than that. Start with ping from router (ping 192.168.255.129 interface=etherX), then ping from 192.168.255.130, check what packets you see on interfaces (with Tools->Torch or using logging rules), things like that, and you should find where exactly it fails.
tangent
Long time Member
Long time Member
Wed Feb 02, 2022 12:32 pm
I can explain the symptom two ways.
1. This RB5009 isn't the Chrome machine's gateway, so the packets are going to some intervening device (e.g. a wifi router) which is rejecting the packets. For this dstnat scheme to work, the RB5009 has to be the next hop on the network.
2. The target device speaks HTTP/1.1 and is looking at the Host header, and it's rejecting the connection attempt because it doesn't say "Host: 192.168.255.129". Destination NATting won't rewrite HTTP headers. You can verify this by digging deeper. The Network tab in the Chrome developer tools may help. Or, try a command line tool with verbose logging, such as curl. Alas, if this is the problem, fixing it may be quite difficult, since HTTPS complicates proxying and header rewriting.
Sob
Wed Feb 02, 2022 12:54 pm
1. It shouldn't be this, because it is (should be) same /24 subnet everywhere.
tangent
Long time Member
Long time Member
Wed Feb 02, 2022 1:50 pm
Fair point. Could it be a bad interaction between dstnat and ARP? When the client asks for the MAC of one of these NATted devices, do you have to configure the router to answer on behalf of the device? They'll certainly ignore ARP for those made-up IPs.
Sob
Wed Feb 02, 2022 2:00 pm
Addresses used to access devices (.11, .12, ...) exist on router, so there's no problem in this direction (from client .130). Opposite direction (from .129 devices) is handled by proxy arp on interfaces (ether2+) they are connected to.
But dstnat, that's it, I forgot to post dstnat rules:
add action=dst-nat chain=dstnat dst-address=192.168.255.11 to-addresses=192.168.255.129
add action=dst-nat chain=dstnat dst-address=192.168.255.12 to-addresses=192.168.255.129
Oops.
tangent
Long time Member
Long time Member
Wed Feb 02, 2022 2:10 pm
Yay, Cunningham's Law triumphs once again! 😛
Users browsing this forum: Ace92 and 9 guests
