gontash
Forwarding through the VPN PPTP tunnel
Tue Feb 01, 2022 12:42 pm
I have a PPTP VPN connection between MIKROTIK 1 (server) and MIKROTIK 2 (client). In the LAN MIKROTIK2 there is a web server (port 8123) and I want to access it via WAN MIKROTIK1. I have a connection established between MIKROTIK 1 and MIKROTIK 2. From the VPN tunnel I can access the web server (port 8123). I cannot access the web server from outside via WAN MIKROTIK 1. What is missing in the configuration ? Help please.
MIKROTIK 1 - SERVER
feb/01/2022 02:32:25 by RouterOS 7.1.1
# software id = A0MX-YB8P
# model = 951G-2HnD
# serial number = xxxxxxxxxxxxx
add admin-mac=xxxxxxxxxxxxxxx arp=proxy-arp auto-mac=no comment=defconf fast-forward=no name=bridge
set [ find default-name=ether1 ] mac-address=xxxxxxxxxxxxxxx speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=poland disabled=no frequency=auto \
    mode=ap-bridge ssid=ProCivili station-roaming=enabled wireless-protocol=802.11
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/interface wireless channels
add band=5ghz-a/n/ac frequency=2412 list=List1 name=ch1 width=20
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.0.10-192.168.0.254
add name=dhcp-pptp ranges=192.168.2.10-192.168.2.254
add address-pool=dhcp authoritative=after-2sec-delay interface=bridge name=defconf
/ppp profile
add bridge=bridge local-address=192.168.2.1 name=pttp-p1 only-one=yes remote-address=192.168.2.2 use-encryption=yes
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing ospf instance
add name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/interface bridge nat
add action=accept chain=srcnat disabled=yes
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2-master
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge ingress-filtering=no interface=ether3
add bridge=bridge ingress-filtering=no interface=ether4
add bridge=bridge ingress-filtering=no interface=ether5
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=wlan1 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add interface=ether1 list=WAN
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/interface wireless access-list
add mac-address=48:D6:D5:0A:B7:84
add mac-address=5C:C3:07:B3:10:DD
add mac-address=54:88:0E:67:98:28
add mac-address=78:02:F8:A9:6A:3D
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=accept chain=input comment="PPTP Conf" dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=input comment="Track Car" dst-port=8123 protocol=tcp
add action=accept chain=forward comment=WWW dst-port=80 protocol=tcp
add action=accept chain=forward comment="NMEA Con" dst-port=5002 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related \
    hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
add action=dst-nat chain=dstnat dst-address=xxxxxxxWAN ADDRxxxxxx dst-port=8123 log=yes log-prefix=Track protocol=tcp \
    to-addresses=192.168.10.82 to-ports=8123
add action=masquerade chain=srcnat dst-address=192.168.10.82 dst-port=8123 log=yes log-prefix="hassio masq" protocol=tcp \
    src-address=192.0.0.0/8
add action=masquerade chain=srcnat dst-address=192.168.10.1 dst-port=80 protocol=tcp src-address=192.0.0.0/8
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxxxxxWAN ADDRxxxxxx dst-port=80 log=yes log-prefix=WWW protocol=tcp \
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxxxxxWAN ADDRxxxxxx dst-port=5002 log=yes log-prefix=GPS_TRACK \
    protocol=tcp to-addresses=192.168.1.100
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.1.100 dst-port=21 protocol=tcp src-address=\
    192.0.0.0/8
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxxxxxWAN ADDRxxxxxx dst-port=21 log-prefix=FTP protocol=tcp \
add action=accept chain=dstnat disabled=yes dst-port="" in-interface-list=*0 protocol=tcp
add check-gateway=ping disabled=yes distance=1 dst-address=192.168.10.0/24 gateway=<pptp-SW> pref-src="" routing-table=\
    main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp secret
add name=gontash profile=pttp-p1 remote-address=192.168.2.3 service=pptp
add local-address=192.168.2.1 name=SW profile=pttp-p1 remote-address=192.168.2.2 routes=192.168.10.0/24,192.168.2.2 \
    service=pptp
/system clock
set time-zone-name=Europe/Warsaw
/system leds
set 0 interface=wlan1
/tool graphing interface
add
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool netwatch
add host=192.168.1.100
/tool sniffer
set filter-direction=tx filter-interface=ether2-master
/tool traffic-monitor
add interface=ether1 name=tmon1 threshold=0 trigger=always
MIKROTIK 2 - ClIENT
# feb/01/2022 10:44:18 by RouterOS 7.1
# software id = 2FVK-KQSX
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = xxxxxxxxxxxxxxxxxx
/interface pptp-client
add add-default-route=yes comment="Link To Router Obywatelska" connect-to=\
    xxxxxxxxxxx keepalive-timeout=disabled name=Obywatelska user=SW
add connect-to=xxxxxxxxxxxxx disabled=no name=Obywatelska2 user=SW
add admin-mac=xxxxxxxxxxxxx arp=proxy-arp auto-mac=no comment=defconf name=\
    bridge
set [ find default-name=ether1 ] arp=proxy-arp name=ether1-WAN
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=xxxxxxxxxxx \
set [ find default-name=wlan2 ] disabled=no mode=ap-bridge ssid=xxxxxxxxxxx \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
add name=dhcp ranges=192.168.10.3-192.168.10.254
add address-pool=dhcp interface=bridge name=LAN
/routing table
add fib name=VPN
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
add bridge=bridge disabled=yes ingress-filtering=no interface=ether1-WAN
/ip settings
/ipv6 settings
add interface=ether1-WAN list=WAN
add address=192.168.10.1/24 interface=ether2 network=192.168.10.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.10.112 client-id=1:28:ee:52:9c:16:4c comment=AP2 \
    mac-address=28:EE:52:9C:16:4C server=LAN
add address=192.168.10.251 client-id=1:24:28:fd:10:76:a0 comment=REJESTRATOR \
    mac-address=24:28:FD:10:76:A0 server=LAN
add address=192.168.10.2 comment=NETGEAR mac-address=CC:40:D0:56:98:64 server=\
    LAN
add address=192.168.10.111 client-id=1:28:ee:52:9c:14:62 comment=AP1 \
    mac-address=28:EE:52:9C:14:62 server=LAN
add address=192.168.10.244 client-id=1:1c:4d:70:5d:21:59 comment=GETAC \
    mac-address=1C:4D:70:5D:21:59 server=LAN
add address=192.168.10.100 client-id=1:94:c6:91:11:1d:dd comment=NUC \
    mac-address=94:C6:91:11:1D:DD server=LAN
add address=192.168.10.0/24 comment=defconf gateway=192.168.10.1 netmask=24
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
    established,related,untracked
    dst-port=80 ipsec-policy=out,ipsec protocol=tcp
    ipsec-policy=in,ipsec
add action=accept chain=input comment="accept HASSIO" dst-port=8123 protocol=\
    tcp
    in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.10.82 \
    dst-port=8123 log=yes log-prefix=MASQ protocol=tcp src-address=192.0.0.0/8
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=8123 log=yes \
    log-prefix=Przekierowaniue protocol=tcp to-addresses=192.168.10.82 \
    to-ports=8123
add disabled=yes dst-address=0.0.0.0/0 gateway=Obywatelska routing-table=VPN
add comment="Dost\EAp do LAN ROUTER 1" disabled=no distance=1 dst-address=\
    192.168.0.0/24 gateway=192.168.2.1 pref-src=0.0.0.0 routing-table=main \
/system clock
/system package update
set channel=long-term
/tool mac-server
Sob
Re: Forwarding through the VPN PPTP tunnel
Tue Feb 01, 2022 3:09 pm
You want some magle rules. Enable the route in routing table VPN you already added. Then mark new incoming connections from Obywatelska interface, and mark routing for response packets belonging to these marked connections, to use VPN routing table.
gontash
Wed Feb 02, 2022 10:42 am
Can you help create these rules? Never used it before.
Added mark connections but doesn't work. I am probably making a mistake somewhere. Actual configuration in MIKROTIK 1
# feb/01/2022 15:58:31 by RouterOS 7.1.1
# model = 951G-2HnD
add admin-mac=xxx arp=proxy-arp auto-mac=no comment=defconf fast-forward=no name=bridge
set [ find default-name=ether1 ] mac-address=xxx speed=100Mbps
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=poland disabled=no frequency=auto mode=ap-bridge ssid=ProCivili \
add name=mactel
add name=mac-winbox
add name=WAN
/interface lte apn
add name=dhcp ranges=192.168.0.10-192.168.1.254
/ppp profile
add name=default-v2
/routing ospf area
/routing table
add fib name=ThroughVPN
/snmp community
/ip settings
/ipv6 settings
/ip dhcp-client
/ip dns static
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
/ip firewall mangle
add action=mark-connection chain=prerouting disabled=yes new-connection-mark=port_8123 passthrough=yes protocol=tcp src-address=192.168.0.0/24 src-port=8123
add action=mark-routing chain=prerouting dst-address=xxxWAN IPxxx dst-port=8123 in-interface=ether1 new-routing-mark=ThroughVPN passthrough=yes protocol=tcp
add action=dst-nat chain=dstnat dst-address=xxxWAN IPxxx dst-port=8123 log=yes log-prefix=Track protocol=tcp to-addresses=192.168.10.82 to-ports=8123
add action=masquerade chain=srcnat dst-address=192.168.10.82 dst-port=8123 log=yes log-prefix="hassio masq" protocol=tcp src-address=192.0.0.0/8
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxWAN IPxxx dst-port=80 log=yes log-prefix=WWW protocol=tcp to-addresses=192.168.10.82
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxWAN IPxxx dst-port=5002 log=yes log-prefix=GPS_TRACK protocol=tcp to-addresses=192.168.1.100
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.1.100 dst-port=21 protocol=tcp src-address=192.0.0.0/8
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxWAN IPxxx dst-port=21 log-prefix=FTP protocol=tcp to-addresses=192.168.1.100
add check-gateway=ping disabled=no distance=1 dst-address=192.168.10.0/24 gateway=192.168.2.2 routing-table=ThroughVPN scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
/ip ssh
/ppp secret
add local-address=192.168.2.1 name=SW profile=pttp-p1 remote-address=192.168.2.2 routes=192.168.10.0/24,192.168.2.2 service=pptp
/system clock
/system leds
add
/tool mac-server
/tool netwatch
/tool sniffer
Sob
Re: Forwarding through the VPN PPTP tunnel  [SOLVED]
Wed Feb 02, 2022 12:07 pm
This should do the trick:
/ip firewall mangle
add chain=prerouting in-interface=Obywatelska connection-state=new action=mark-connection new-connection-mark=from-vpn
add chain=prerouting in-interface=bridge connection-mark=from-vpn action=mark-routing new-routing-mark=VPN
Don't forget to enable that route in routing table "VPN".
Btw, internal address 192.168.10.1/24 should be on bridge, not on ether2, because ether2 is member port of that bridge (but it's not really breaking anything). And PPTP is outdated and insecure, so it's better to use something else.
gontash
Wed Feb 02, 2022 7:03 pm
/ip firewall mangle
Thanks a lot! You are my master! It works :D :D :D
Users browsing this forum: No registered users and 13 guests
