PolPin
ros_command set variable from dude
Thu Feb 03, 2022 1:02 pm
I have a question for you, is it possible to send a variable, eg [Device.CustomField2] in ros_command.
I want to write a universal function that will retrieve the appropriate parameter
ros_command(":local clientIP [Device.CustomField2]; :local peer; :local ph2; :foreach line in=[/ip ipsec policy print as-value where disabled=no and template!=yes and sa-dst-address=$clientIP] do={:foreach name,item in=$line do={if ($name=\"peer\") do= {:set peer $item}; if ($name=\"ph2-count\") do= {:set ph2 \"\"; if ($item=0) do={:set ph2 \"DOWN\"}; if ($item>0) do={:set ph2 \"UP\"};}; }; :put ($peer.\" \".$ph2)}")
excession
Re: ros_command set variable from dude
Wed May 04, 2022 12:09 pm
+1 I'm also curious if there's a syntax that will make this work.
rextended
Re: ros_command set variable from dude  [SOLVED]
Wed May 04, 2022 1:18 pm
The Dude code
ros_command(concatenate(":global test \"",device_property("Name"),"\""))
excession
Thu May 12, 2022 11:07 pm
Thank you! :)
boredwitless
Fri Aug 04, 2023 12:50 pm
The Dude code
Is it possible to pass other information into ros_command other than from the device_property() function - I'm trying to pass [Interface.Name] into a ros_command to return the IP Address assigned to that interface.
ros_command(concatenate(":put [ip address get [find interface=",[Interface.Name]," ] address]"))
Users browsing this forum: No registered users and 62 guests
