what is the equivalent mechanism with version 7 for e.g.
Code: Select all
/ip dhcp-client
add default-route-distance=33 interface=<name>
/routing filter
add chain=dynamic-in distance=33 set-check-gateway=ping set-distance=1
Modify attributes of default route set by dhcp-client.
Haven't found a solution in documentation, forum or by experimenting.
Thanks a lot! Regards
Lutz
