armandfumal
BGP V7 Prefixe
Fri Feb 04, 2022 1:40 pm
HI,
Could somebody can tell me how to do it in V7 these V6 command ?
routing bgp advertisements print <peer_name>
ip route print where received-from=<peer_name>
thanks
Armand
jd603
Re: BGP V7 Prefixe
Wed Feb 16, 2022 11:58 pm
You can't. They have not implemented this (routing bgp advertisements) yet. It's a big one I know.
gechev
Re: BGP V7 Prefixe
Thu Feb 17, 2022 10:15 am
/routing/route/print where belongs-to="BGP IP routes from <peer_ip>"
I don't think it's designed to be the solution, I found it to be workaround for now, as it is not foolproof at all - a long string, space and case sensitive, strict search.
armandfumal
Re: BGP V7 Prefixe
Mon Mar 21, 2022 12:51 pm
Hi, thanks for the answer, it works but only received route, I need to know what I'm sending...
regards
pe1chl
Re: BGP V7 Prefixe
Mon Mar 21, 2022 2:44 pm
For now the only solution is to do a packet sniffer capture (set a filter on TCP port 179) to a file, let it run for a while or close/open the peering session, then download the file and view it in wireshark.
armandfumal
Re: BGP V7 Prefixe
Wed Mar 23, 2022 5:02 pm
Today in 7.2RC5
*) bgp - added BGP advertisements display (requires output.keep-sent-attributes to be set);
*) routing - added PCAP viewer tool for BGP advertisements debugging purposes;
mrz
Re: BGP V7 Prefixe  [SOLVED]
Wed Mar 23, 2022 5:04 pm
Users browsing this forum: No registered users and 26 guests
