mushmx
Plz security 128bit wep
Thu Sep 06, 2007 9:58 pm
8) Hi....i need configure the AP with 128 Bit WEP security....but I only view 104bit and 40bit....plz help if someone know....how to do...
Best Regard.......... :)
sergejs
Re: Plz security 128bit wep
Fri Sep 07, 2007 3:14 pm
104 is the same as 128, different vendors use different description.
Use 128 encryption, it should work fine.
wildbill442
Fri Sep 07, 2007 7:34 pm
mushmx
Sat Sep 08, 2007 7:26 am
Thank you... :D for you help...but i've doubt respect about the hexadecimal and decimal password.....In this case i need a hexadecimal password to my AP.
I selected a 104 bits WEP but my password must be a hexadecimal password. how to write a hexadecimal password? I'm confused because i view 0X before the textbox.
Sorry for my bad english :lol:
Best regard.
wildbill442
Mon Sep 10, 2007 7:50 pm
0x{insert password here}
example:
[40bit]
0x0102030405
[104bit]
0x0102030405060708090a0b0c0d
Entered on a client system would be in the format the local operating system or wireless software supports.
mushmx
Tue Sep 11, 2007 7:01 am
Thank very much for you help!!! :D
Best regard.
Users browsing this forum: No registered users and 32 guests
