MUM Europe 2020
pospanko
Interface based routing?
Fri Sep 07, 2007 11:16 am
Can someone help me with that?
I tryed everything but no result. I couldn't use routing from same computer because I use 2 connections from same ISP, and the hava a same network. Now, when interface routing is available I can set it up.
I use policy routing but all trafic is going to 1.interace....
sergejs
Re: Interface based routing?
Fri Sep 07, 2007 3:09 pm
interface routing configuration is the following,
'ip route add gateway=<interface>', it should work fine for point-to-point interface.
What kind of connection with two gateways you have ?
pospanko
Fri Sep 07, 2007 3:45 pm
Maybe I was a little bit unprecise. I connect to my ISP over pppoe connections. I have a two ADSL lines. Until now i couldn't use two connections to ISP from same machine because my gateweys was the same. Now with interface based routing I can do that. But, I followed a manual from wiki http://wiki.mikrotik.com/wiki/Policy_Ro ... erOS_2.9.x but with no sucess. When I add new rule to /ip route rule, MT discconect me and I can log in anymore. I have to mac-telnet and remove the rule. When there is no rule, MT uses only one pppoe-out....
I hope that I'm a little bit precise this time...
P.S. Thx Sergejs for helping me
Equis
Forum Veteran
Forum Veteran
Sat Nov 22, 2008 8:22 am
Hello
Sorry to dig up an old post but this is what I would like to do also.
I have 2 connections to the same ISP with same GW IP address.
Will V3 allow me to route via interface even tho GW IP is the same?
pospanko
Sat Nov 22, 2008 11:32 am
Yes. In v3 it works like a charm. Just use interface as a gateway.
Chupaka
Sat Nov 22, 2008 12:35 pm
interface routing - is it when automatic gateway address on specified interface selected?
what if I need to add some kind of 'connected' route? i.e. advertise connected network on interface, but have no IP address on that interface?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Fri Nov 28, 2008 10:21 am
when you say "routing" you say in current situation you say - ISO layer 3
Chupaka
Fri Nov 28, 2008 11:23 am
yep. for example, asymmetric routing, when on ether1 you have an address 10.0.0.1/24, on ether2 you do not have an address, but you know that behind ether2 there is 10.10.10.0/24 network, and their gateway address (10.10.10.1) is on other router. i.e. packets are only received via first router, and sent via another one. so is there a possibility at advertise 10.10.10.0/24 network on ether2 without adding an address (10.10.10.254/24, for example) to interface?
Users browsing this forum: barracuda, MSN [Bot] and 86 guests
