enlace101
Reemplace hap ac3 need poe out
Fri Feb 11, 2022 4:10 pm
do you know any poe out router to replace mikrotik hap ac3? (Wisp)
Need bridge Mode..
Zacharias
Re: Reemplace hap ac3 need poe out
Fri Feb 11, 2022 4:25 pm
Have you checked the products page ? https://mikrotik.com/products
Also, what are the requirements ? Except the POE-out ...
enlace101
Fri Feb 11, 2022 4:36 pm
No mikrotik, wifi is slow
Zacharias
Fri Feb 11, 2022 4:43 pm
You ask in the MikroTik forum , suggestion for a non MikroTik device ?
enlace101
Fri Feb 11, 2022 5:06 pm
I understand that it may be considered inappropriate to search this forum for a replacement for mikrotik products.
I think it is easier for those who know the device (hap AC3) to recommend a replacement with poe OUT that better fulfills the Wi-Fi functions of a Home.
Our ISP gives us internet through Mikrotik Cube60 AC 300/100Mbs.
hAP AC3 is not capable of moving this speed in noisy environments.
Any recommendation?
Thanks a lot
Rox169
Thu Jun 16, 2022 4:55 pm
I have mikrotik as main router and Asus RT-AX56U as AP. It has WiFi 6, is very powerfull and has roaming 802.11r. Once set up, you can forget about AP very solid.
holvoetn
Thu Jun 16, 2022 5:20 pm
Oh but I respectfully disagree there.
I can easily push close to 500Mb (sometimes more) using hAP AC3 using 5Ghz on my internal network.
So 300/100 shouldn't be a problem either (I only have 200/20 at home to the outside world).
I do agree it required some careful monitoring from my side which channels to use but it's not rocket science either.
Especially wifiwave2 should help a lot.
gotsprings
Thu Jun 16, 2022 7:47 pm
While I can get around 700M per seconds on WiFi 6 from other vendors...
holvoetn
Thu Jun 16, 2022 8:53 pm
Sure you can but that does not take away the fact hAP AC3 is more then capable to handle 300/100 which OP claims to be a problem right now.
It is not the device. It's the config which most likely is the problem.
gotsprings
Fri Jun 17, 2022 2:41 am
If he used the standard drivers or caps-man... 300 is a gift.
Also even with the Wave 2 driver... It's best client serving wifi I have ever seen from Mikrotik. But it's about equal to other ACv2 wifi devices from 2016.
Users browsing this forum: Amazon [Bot] and 36 guests
