GiovanniG
Can be Ubiquiti access point managed by Mikrotik Capsman?
Tue Feb 15, 2022 5:47 pm
Hi, I have 2 ubiquiti wifi antennas, are them somehow compatible with Capsman?
In case the board/hardware is the same, is it eventually possible to load on them Mikrotik firmware? Thank you a lot
anav
Re: Can be Ubiquiti access point managed by Mikrotik Capsman?
Tue Feb 15, 2022 5:49 pm
Nope! Capsman is proprietary.
GiovanniG
Tue Feb 15, 2022 5:50 pm
ok, hardware is completely different?
erlinden
Tue Feb 15, 2022 5:52 pm
This is a software issue.
GiovanniG
Tue Feb 15, 2022 5:54 pm
it's impossible to flash there RouterOS?
tomaskir
Trainer
Trainer
Tue Feb 15, 2022 8:39 pm
It is NOT possible to flash RouterOS on UBNT hardware.
Users browsing this forum: No registered users and 94 guests
