Ernstm
Help with remove Command
Thu Feb 17, 2022 11:52 am
Hi
Please could someone assist me with this?
I need script to remove sip connections every hour. I have tried the following
/ip firewall connection remove [/ip firewall connection find where connection-type=sip]
I also tried to mark the connections and then
/ip firewall connection remove [/ip firewall connection find where connection-mark=SIP]
Also tried --- /ip firewall connection remove numbers=[/ip firewall connection find where connection-mark=SIP]
and --- /ip firewall connection remove numbers=[/ip firewall connection find where connection-type=sip]
None of these have any effect.
Please can someone show me what I am doing wrong?
Jotne
Re: Help with remove Command
Thu Feb 17, 2022 12:17 pm
What is the output of:
:put [/ip firewall connection find where connection-type=sip]
and
:put [/ip firewall connection find where connection-mark=SIP]
If its more than one, you may need to loop trough it.
pudl
Thu Mar 03, 2022 3:40 pm
I am using this script for removing rogue SIP connections:
:global SIP [ /ip firewall connection find where connection-type=sip and assured=no ];
:global SRC [ /ip firewall connection get $SIP src-address ];
:global DST [ /ip firewall connection get $SIP dst-address ];
:global currentSIP [ :toarray $SIP ];
:global message "SIP - delete non-assured connections: SRC:$SRC DST:$DST";
:if ( $currentSIP="" ) do={
                 /log info "SIP - no non-assured connections"
} else={
                /ip firewall connection remove $currentSIP;
#                /tool e-mail send server=******** user=******** password=******* to=******** body=$message;
               /log info "SIP - delete non-assured connections: SRC:$SRC DST:$DST";
              /tool e-mail send to="*********" subject="SIP!" body=$message;
I set the scheduler to run it every 3 minutes.
Users browsing this forum: No registered users and 29 guests
