moly
wireless problem in 3.0xx, low thruput, high latency
Sat Sep 08, 2007 10:17 pm
Hi, help me, i have RB532 and CM9 card as AP and clinet Ovislink WL-5460AP. In version 2.9.x its all great, high thruput and low latency. If upgrade to 3.0xx, all is bad. Thruput abou 700kbps and ping about 300 - 1500ms :( . The same problem with NTB HP compaq. I testing the new RB333 and its suport only 3.0xx and problem is the same, but no way to 2.9.xx :( . Siganl is good -60dB.
Pleas help me, is some bug in ROS or only configuratin problem?
Thanx
moly
Re: wireless problem in 3.0xx, low thruput, high latency
Sat Sep 08, 2007 10:26 pm
Some screenshot, upset in registration table, and normal latenci in idle, no trafic. :(
changeip
Sun Sep 09, 2007 6:53 pm
which version of 3.0 are you using? I believe I read they fixed that in the latest RC.
Sam
moly
Sun Sep 09, 2007 8:02 pm
3.0rc4 on RB333
BrianHiggins
Long time Member
Long time Member
Mon Sep 10, 2007 4:42 pm
umm.. how does your wireless client have a mac address of 00:00:00:00:00?
moly
Mon Sep 10, 2007 4:54 pm
but, my clinet not have 00:00:00:00:..... Have real MAC 00:4F:62:....... , but in registration table is wrong, and also interface "unknown".
uldis
Mon Sep 10, 2007 5:02 pm
please make the support output file and send it to support@mikrotik.com
moly
Mon Sep 10, 2007 5:50 pm
ok, i send supout and mor info, thanx
Users browsing this forum: Majestic-12 [Bot] and 76 guests
