erkexzcx
[ROS7] How to get public IP (sort of)
Sun Feb 20, 2022 10:03 am
TL;DR
Get a cloud VM with public IP, host wireguard server on it, connect to it from Mikrotik router, port forward everything from VM to Mikrotik via wireguard tunnel.
Other notes:
  • Linode provider offers cheapest instance for 5$/month and you get 4TB of monthly TX data. RX data is not counted (free).
  • ip/cloud assigned ddns no longer works. Consider using your own domain or free DDNS duckdns.org.
  • By using below method you won't be able to use ports 22/tcp and 51820/udp (they can be changed tho).
Use-case
Your ISP (so basically anyone who lives on mobile data) does not have public IP and therefore cannot host anything on their home network. My specific use case was Homeassistant server at home and I wanted my phone to send my location to it, but it was not possible when there is no direct connectivity. Solution - I needed direct connectivity from the internet to my router which port forwards to my server.
Instructions
Go to linode.com and order cheapest (shared CPU, 1 core, 1GB of RAM, 5$/month) instance with latest Rocky Linux. At the time of writing I used Rocky Linux 8.
Connect to the instance via SSH, root user and execute the following commands by literally copying & pasting them all into the terminal:
# Update system
dnf update -y --refresh
# Install additional repos
dnf install -y elrepo-release epel-release
# Install wireguard tools
dnf install -y kmod-wireguard wireguard-tools
# Stop & disable firewalld
systemctl disable --now firewalld.service
# Enable IP forwarding
sysctl -w net.ipv4.ip_forward=1
sysctl -w net.ipv6.conf.all.forwarding=1
sysctl -a | grep all.forwarding > /etc/sysctl.conf
# Generate wireguard keys
cd /etc/wireguard && wg genkey | (umask 0077 && tee server.key) | wg pubkey > server.pub
cd /etc/wireguard && wg genkey | (umask 0077 && tee client.key) | wg pubkey > client.pub
# Create wireguard server config file /etc/wireguard/wg0.conf
cat <<EOT > /etc/wireguard/wg0.conf
[Interface]
Address = 10.200.200.1/24
ListenPort = 51820
PrivateKey = $(</etc/wireguard/server.key)
PostUp = iptables -t nat -A PREROUTING -p tcp --dport 22 -j ACCEPT; iptables -t nat -A PREROUTING -p udp --dport 51820 -j ACCEPT; iptables -t nat -A PREROUTING -j DNAT --to-destination 10.200.200.2; iptables -t nat -A POSTROUTING -j MASQUERADE
PostDown = iptables -t nat -D PREROUTING -p tcp --dport 22 -j ACCEPT; iptables -t nat -D PREROUTING -p udp --dport 51820 -j ACCEPT; iptables -t nat -D PREROUTING -j DNAT --to-destination 10.200.200.2; iptables -t nat -D POSTROUTING -j MASQUERADE
# Mikrotik router
[Peer]
PublicKey = $(</etc/wireguard/client.pub)
AllowedIPs = 10.200.200.2/32
EOT
# Generate Mikrotik commands list by executing below multiline command
cat <<EOT > /etc/wireguard/mikrotik_commands.txt
# Create wireguard interface
/interface wireguard add listen-port=13235 mtu=1420 name=wg99 private-key="$(</etc/wireguard/client.key)"
# Connect to the wireguard server
/interface wireguard peers add allowed-address=10.200.200.0/24 endpoint-address=$(curl -sL https://ipv4.wtfismyip.com/text) endpoint-port=51820 interface=wg99 persistent-keepalive=25s public-key="$(</etc/wireguard/server.pub)"
# Set IP for wireguard interface
/ip address add address=10.200.200.2/24 interface=wg99 network=10.200.200.0
# Exclude such traffic from fasttrack/allow in firewall
/ip firewall filter add action=accept chain=forward in-interface=wg99 place-before=[find where action=fasttrack-connection]
/ip firewall filter add action=accept chain=forward out-interface=wg99 place-before=[find where action=fasttrack-connection]
EOT
# Enable wireguard server on boot
systemctl enable wg-quick@wg0.service
# Reboot the system
reboot
As you can see the last command reboots your instance. Reconnect to it and print the contents of file
cat /etc/wireguard/mikrotik_commands.txt
This file contains all the generated commands you need to copy & paste (all at once) into your Mikrotik terminal and execute them.
Once done, you should have connectivity from Linode's instance public IP address. Try port forwarding port in your Mikrotik router and checking port on your Linode's instance IP - it should return what your router is supposed to return.
Note that the traffic is coming from wg99 interface, IP 10.200.200.1, so you might need to adjust your port forwarding rules accordingly.
jvanhambelgium
Re: [ROS7] How to get public IP (sort of)
Sun Feb 20, 2022 2:30 pm
Alternative, if Home Assistant is your only use-case, is just to use Nabu Casa / Home Assistant Cloud cloud service.
Slightly more expensive at 6.5USD/month but a much more simple setup, directly from your HA -> SaaS platform.
Hominidae
Mon Feb 21, 2022 1:50 pm
2nd variant: ...get a VPS (KVM) that allows to install your own image (mine is approx 3USD/month, 1vCPU, 2GB RAM, 20GB SSD, 40TB traffic - but anything with 512MB+ RAM will do fine) and host/install a Mikrotik CHR on it.
erkexzcx
Mon Feb 28, 2022 12:07 pm
...and host/install a Mikrotik CHR on it.
CHR costs money and if you want it free - you are limited to 1mbps only.
infabo
Mon Feb 28, 2022 10:37 pm
Zerotier?
anav
Sun Mar 06, 2022 9:25 pm
Zerotier?
Not all devices have access to zerotier.
aliboy
Wed Mar 09, 2022 9:06 am
TL;DR
Other notes:
Use-case
Instructions
# Update system
[Interface]
ListenPort = 51820
# Mikrotik router
[Peer]
EOT
EOT
# Reboot the system
reboot
Thank you. This is helpful. I just don't know how to do the last part. Say I have the default configuration in the Mikrotik router (192.168.88.1 as the LAN address) and I followed the instructions to configure the Wireguard and peers in Mikrotik router, if I have to do the port forwarding in Mikrotik should I do this in Firewall?
General:
chain = dstnat
Dst. Address = <public IP of the Virtual Server>
Action:
action = dst-nat
To Addresses = 192.168.88.1
Hominidae
Wed Mar 09, 2022 9:28 am
Your solution is *not* free, too.
....running one year of your linode VPS is as expensive as my VPS (1 year) + one, onetime P1 CHR licence...at least in my calc sheet, just sayin'
aliboy
Fri Mar 11, 2022 12:19 am
TL;DR
Other notes:
Use-case
Instructions
# Update system
[Interface]
ListenPort = 51820
# Mikrotik router
[Peer]
EOT
EOT
# Reboot the system
reboot
How do I go about the fort forwarding in the Mikrotik router?
Ports are not specified anymore because it will be for all, is this correct?
General:
chain = dstnat
Action:
action = dst-nat
Hominidae
Fri Mar 11, 2022 5:32 pm
...in this setup, there is no need for port-forwarding on the MT router.
MT router will enable the link to VPS via its wg enpoint-configuration in the peer to VPS, hence overcoming the CGNAT limitation of the local MT WAN-Link.
Once the tunnel is established, it will be fully bi-directional, even if opened from only from one side.
I think what was meant instead of "forwarding rules" is "adjust rules in the forward chain", since traffic over wg-interface will be routed via 10.200.200.0/24 net and ip addresses attached to the wg-interface.
If your local MT has a standard firewall setup, i.e. like this: https://help.mikrotik.com/docs/display/ ... d+Firewall
...just add the wg-interface to the LAN interface-list of the MT: /interface list member add interface=wg99 list=LAN
aliboy
Sun Mar 13, 2022 12:25 am
Thanks Hominidae! I was able to add the wg interface to the LAN list (and WAN list). Both or either of them works and I don't know the difference but as of now, it is just in the LAN list.
The VPS shows that a peer is connected. The peer is my Mikrotik Router. I can now ping the 10.200.200.2 from VPS and I can ping 10.200.200.1 from any device in my local network. I was able to do the port forwarding in Mikrotik to forward all tcp and udp to a local server that has an IP address of 192.168.88.50. The port forwarding is working based on my test.
I am not an expert when it comes to networking but my understanding is, it has this direction now:
any public IP > public IP of the VPS > My Mikrotik > a local server
The local server still communicates to the internet but it uses the public IP of my mobile data network which is in CGNAT. I would like the local server to use the 10.200.200.1 network to communicate to the internet so that if I check its public IP, it will show the public IP of the VPS. Is this possible or is this part of the limitations in this kind of setup?
So far, this is what I did but the local server is unable to connect to the internet but the port forwarding is still working:
Table: I create a table called "wg".
Firewall > Mangle: A mangle that has a "Src Address List" = LocalServerName (the IP address is declared on the Address List) is set to "Mark Routing" and uses the "wg" table name.
Route List: Gateway:10.200.200.1 and "Routing Table" = wg
Hominidae
Sun Mar 13, 2022 2:03 am
OK, now I got it.
So the inbound traffic from VPS to your local net works. What is not working is that local host is not using VPS as gateway.
This is how I am doing this (I do this, in order for my VOIP-PBX to use the VPS as a constant WAN IP/GW, regardless of the actual IPs of my local, multiple WANs)
- have/create a local IP on VPS (my VPS is running a MT CHR; I created a bridge and added address/IP 192.168.255.254/32 to it.
- make sure that VPS has a valid default route and outbound NAT (when doing a ping from local interface/192.168.255.254 on VPS, it will use its own WAN interface and outbound Internet access works)
- on local MT create a route to VPS-IP with gateway being the remote IP/VPS-side of wg-interface (you should be able to ping the VPS IP from your local net via wg-tunnel, hence).
- on local MT create two address lists 1. all IPs of local hosts that should use VPS as WAN-gateway 2. all IPs that should *not* be routed to VPS, i.e. all your local networks
- on local MT create a mangle rule in firewall: chain=prerouting, src-address-list = list#1, dst-address-list != list#2, action route, route-dst=192.168.255.254 (local IP of VPS) Edit: note do set dst-list *not*-equal-to list#2
...works like a charm for me
aliboy
Sat Mar 19, 2022 10:09 am
Hi Hominidae,
I was able to setup a Mikrotik CHR. It has just the default configuration. My understanding is this:
Mkrotik CHR (public IP) <------wireguard tunnel------> my local Mikrotik (CGNAT)
In configuring the wireguard of the local Mikrotik, I put the public IP of the Mikrotik CHR is the endpoint peer. How about in the Mikrotik CHR, what is the endpoint IP I should put?
Thanks!
aliboy
Sun Mar 20, 2022 12:54 pm
Do I have to buy a CHR license or the free version is good?
Hominidae
Sun Mar 20, 2022 6:02 pm
...not needed.
The local MT will use the endpoint config to initiate the tunnel to the CHR. As it is behind CGNAT, the CHR can't reach/connect to it anyway.
Once the tunnel is up, it will be bi-directional.
Keep an eye on the persistent keepalive setting in wg-peer ...it should be smaller than the connection timeout in the firewall in order to prevent the conntrack to kick in and delete the connection in your NAT/conntrack table.
AFAIR my conntrack timeout for UDP connections is set to 2mins...I have my keepalive settings around 22-25secs.
For testing purposes, it will work. But the free License is limited to 1Mbps only. AFAIR, when you activate a test license (P1 = 1G) it will run for 30days and fallback to free (1M) afterwards.
So you have some time to test and evaluate. A CHR license is never lost but only bound to a single instance at a time. You can tear down your install and build another later, then transfer the license.
..and don't forget to secure your CHR properly ;-)
aliboy
Tue Mar 22, 2022 9:01 pm
Hi Hominidae,
I am still trying my best to accomplish my goal using the method you recommended which is to use a CHR. I have a question about the original post of "erkexzcx". Let's say his method works, that means that I am not limited to 1MBPS of speed only, is that correct?
Thanks!
Hominidae
Tue Mar 22, 2022 11:58 pm
...I am not recommending the use of a CHR, it is just what I do use.
You can of course do that with any VPS, running a linux OS and with iptables and wireguard installed.
But since you do have a MT and know your ways there, why introduce another system type?
A P1 license is not coming with a huge price tag, isn't it?
I do own a couple of these and bought them for prices between 25-35USD over the years....worth every penny, if you ask me.
aliboy
Mon Apr 04, 2022 6:15 am
I think I followed the recommended settings based on the other post in the forum but it still doesn't work.
Whenever I enable the routing rule, the device wouldn't connect to the internet.
My goal is to be able to use the wireguard as gateway so that the public of the device with an IP address of 192.168.88.253 will become 172.104.48.54.
Pinging from VPS to 10.200.200.2 is good. Pinging the Mikrotik (and any devices connected to Mikrotik) to 10.200.200.1 is also good.
Here is the current configuration in the VPS:
[Interface]
ListenPort = 51820
PrivateKey = SPOZPusRrSlt+Tm3clLD164drtkcTtWRbZrI/E+oJFQ=
# Mikrotik router
[Peer]
PublicKey = H1ENrFj2o7A2+BZUgDee2+N0qQRvxpTUML2mQs9agjU=
AllowedIPs = 10.200.200.2/32, 192.168.88.0/24
anav
Mon Apr 04, 2022 3:12 pm
THis is how to get a public IP thread.
If you have a wireguard issue then post a NEW THREAD.............
Sob
Mon Apr 04, 2022 5:09 pm
@aliboy: You have allowed-address=10.200.200.0/24, so nothing else will be allowed to pass. If you want it for traffic from internet, you need 0.0.0.0/0.
anav
Mon Apr 04, 2022 6:31 pm
okay so you want to fill up a how to get a public IP thread with other crap. I can do that.
(1) My recommendation is not to use the same name for the wirgueard interface as the table to direct people to use the wireguard.
/routing table
add disabled=no fib name=useWG99
So that its clear what its for but distinct from the actual wireguard interface name.
(2) Why is your IP address for wg99 10.200.200.2/24 - was it given to you by a third party provider??
By the way the reason Sob suggested 0.0.0.0/0 for allowed IPs, is because he was assuming internet access was desired. Such an astute observation.
The important thing to note here is that 0.0.0.0/0 includes the 10.200...... subnet so you should still be able to ping the server with no issues.
(3) These rules are TOO WIDE OPEN
In other words where to you want the users on your network to go, OR where do you want the users on a remote network to go?
You probably dont need or want both!
Assuming you want to let your LAN users go out 3rd party VPN for internet
add action=accept chain=forward source-address=192.168.88.0/24 out-interface=wg99 is much clearer and accurate.
(4) add you should move those rules (sorry the new singular rule) under the default rules. like right after the drop invalid rule!
(5) OKAY NOW WE HAVE A PROBLEM
/routing rule
add action=lookup disabled=yes src-address=192.168.88.253/32 table=wg99
What are you doing here, this may unnecessary.?
Did you not want your entire subnet to use the third party VPN??
IF not, and lets say you ONLY wanted a single user to use the VPN, then lets make those changes necessary.
Then all you need to do is this.......
add action=accept chain=forward source-address=192.168.88.253/32 out-interface=wg99
If you had a number of IPs on the subnet requiring such
simply make a firewall address list and use src-address-list.
NOTE: I am assuming you have an IP route for the rest of the subnet users, not visible because you have selected YES to ip route in IP DHCP client ????
Sob
Mon Apr 04, 2022 6:43 pm
@anav: So you didn't notice that it's the same thing, only instead of using it for incoming connections, the last question is about outgoing ones? Not much difference.
anav
Mon Apr 04, 2022 6:50 pm
Nope without a diagram or stated requirements, its greek to me! I stay away from assumptions.
aliboy
Tue Apr 05, 2022 2:22 am
I have followed the instructions from the very first post on this thread. I didn't have to configure everything related to Wireguard in Mikrotik as everything is a result of the pasted command on the terminal.
Here is the copy of the command:
/interface wireguard add listen-port=13235 mtu=1420 name=wg99 private-key="qK+H0jPkvBBrJQbp2cYsSIqcVso3kZfBOFGFl3Dxa0s="
/interface wireguard peers add allowed-address=10.200.200.0/24 endpoint-address=172.104.48.54 endpoint-port=51820 interface=wg99 persistent-keepalive=25s public-key="9meO7N1VTUNoDzfUQ78ongdfY5H2Y9xupjbeB+H2t1A="
I will try all your recommendations and will let you know the results after.
kajotsoft
Tue Nov 08, 2022 11:50 pm
Hi
is it possible to get with ssh tuneling? ssh -R somehow? and after that install wireguard on mikrotik and self host in on such kind of forwarded port?
br
KJ
pblvsk
Tue Dec 27, 2022 8:30 pm
thank you for providing this solution, it works well...
Except for the part, where I can access my internal services when using other network than the same LAN.
1. LTE on my mobile > go to domain.com > domain loads
2. Same network as Mikrotik > go to domain.com > domain timed out
Is there any extra step I need to follow for this to work?
bpwl
Mon Feb 13, 2023 11:28 pm
Zerotier?
I always saw Zerotier as a very nice implemenation for STUN/TURN/ICE , where Zerotier has a free public TURN server, and will switch to STUN if possible. If not possible to switch to STUN it will continue on TURN (passing the traffic over the TURN server). STUN goes direct between the 2 involved sites without going over the TURN server, if the "UDP hole punching" or other connection spoofing techniques do work.
https://www.zerotier.com/2014/08/25/the ... traversal/
Maybe there is somewhere a STUN/TURN/ICE server or setup that can be used for Wireguard without access via public IP on all sites with MT.
https://medium.com/orion-innovation-tur ... ce0e967969
