chanchiboy
Recomended Settings Marina AP
Thu Feb 24, 2022 2:35 am
Hi Guys,
I have been playing with the setting for more than 5 years and I got some improvements in the performance but it is still not quite good. I wonder if you can bring some guidance for the best setting for an AP on a Marina Environment, below my actual setup.
PS the wired network works very smooth; the signal strange, CCQ and Signal to notice looks good may said so I think need to improve my setting since a loot of water and boat are around
# feb/23/2022 18:29:33 by RouterOS 6.49.2
# software id = ECJU-6G01
# model = 912UAG-2HPnD
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
band=2ghz-g/n bridge-mode=disabled country=mexico default-authentication=no \
disabled=no frame-lifetime=50 frequency=2427 installation=outdoor mode=\
ap-bridge preamble-mode=long ssid="Dock I" tx-chains=0,1 wireless-protocol=\
802.11
/interface wireless access-list
add interface=wlan1 signal-range=-77..120
/interface wireless cap
set caps-man-addresses=192.168.78.1 certificate=request discovery-interfaces=\
ether1 interfaces=wlan1 lock-to-caps-man=yes
here the stats details
0 interface=wlan1 mac-address=92:91:2F:18:F6:F1 ap=no wds=no bridge=no rx-rate="6.5Mbps-20MHz/1S" tx-rate="26Mbps-20MHz/2S" packets=157,123 bytes=65507,25002
frames=157,123 frame-bytes=64607,24264 hw-frames=438,254 hw-frame-bytes=118038,30488 tx-frames-timed-out=0 uptime=4m40s last-activity=10s700ms
signal-strength=-76dBm@1Mbps signal-to-noise=19dB signal-strength-ch0=-76dBm
strength-at-rates=-76dBm@1Mbps 4m40s10ms,-78dBm@6Mbps 10s700ms,-77dBm@HT20-0 30s910ms,-78dBm@HT20-1 37s660ms,-77dBm@HT20-2 4m39s450ms,-78dBm@HT20-3 4m39s310ms
tx-ccq=34% p-throughput=20005 distance=2 last-ip=192.168.18.43 802.1x-port-enabled=yes management-protection=no wmm-enabled=yes
tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-15"
1 interface=wlan1 mac-address=54:BD:79:21:ED:07 ap=no wds=no bridge=no rx-rate="6.5Mbps-20MHz/1S" tx-rate="43.3Mbps-20MHz/2S/SGI" packets=1230,1558 bytes=234281,185318
frames=1129,1527 frame-bytes=229607,184665 hw-frames=2708,1558 hw-frame-bytes=625327,227869 tx-frames-timed-out=0 uptime=4m33s last-activity=420ms
signal-strength=-78dBm@HT20-0 signal-to-noise=17dB signal-strength-ch0=-78dBm
strength-at-rates=-76dBm@1Mbps 4m33s,-76dBm@6Mbps 4m30s730ms,-78dBm@HT20-0 420ms,-78dBm@HT20-1 16s170ms,-78dBm@HT20-2 4m28s510ms tx-ccq=71% p-throughput=32430
distance=25 last-ip=192.168.18.178 802.1x-port-enabled=yes management-protection=no wmm-enabled=yes tx-rate-set="OFDM:6-54 BW:1x SGI:1x HT:0-15"
Users browsing this forum: Bing [Bot] and 23 guests
