oreggin
ROSv7 RIP doesn't distribute routes
Sun Feb 27, 2022 9:51 pm
Hi!
I use RIPv2 for distribute large number of routes in HUB&Spoke setups with RoSv6. It is very scalable, easily fits thousands of Spokes on a HUB.
I testing it with RoSv7.2rc3 but I see that RoSv7 HUB doesn't send out received RIPv2 routes from other Spokes. It sends out only its own redistributed connected routes. Spokes connects to HUB with raw L2TP.
Test RIP config:
/routing rip instance
add disabled=no name=RIPv2 redistribute=connected
/routing rip interface-template
add instance=RIPv2 interfaces=l2tp-lab-bridge
add instance=RIPv2 interfaces=l2tp-vtkl20
add instance=RIPv2 interfaces=l2tp-vttu69
Hub has 3 Spokes RIPv2 route:
[oreggin@rtr1.vtv35] > /ip/route/print where rip
Flags: D - DYNAMIC; A - ACTIVE; r, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS     GATEWAY    DISTANCE
DAr 192.168.5.0/24  10.1.1.20       120
DAr 192.168.6.0/24  10.1.1.69       120
DAr 192.168.7.0/24  10.1.1.10       120
But on spoke there is only the HUBs route:
[oreggin@rtr1.vtkl20] > /ip/route/print where rip
DAr 192.168.4.0/24  10.1.1.1       120
aleksis
Re: ROSv7 RIP doesn't distribute routes
Tue Mar 01, 2022 8:45 am
Try redistribute=rip,connected.
oreggin
Tue Mar 01, 2022 11:24 pm
Thanks for the hint. I added rip to redistribute on HUB without success. I upgradded all routers to 7.2rc4, no win :-(
oreggin
Sun Mar 27, 2022 1:24 pm
RourerOS v7.2RC5 solve this.
Thanks!
oreggin
Mon Apr 04, 2022 12:22 pm
...and RC7 make it inoperative again :-(
Users browsing this forum: No registered users and 19 guests
