hussamaziz
mikrotik send message to telegram
Thu Mar 03, 2022 10:07 am
hi guys
my mikrotik v 6.49.4
I want to send message to telegram but there is a problem when sending
This is a message that shows the problem
[admin@rb951 home] > tool fetch url="https://api.telegram.org/bot5171614564: ... endMessage
<url> --
address --
as-value --
ascii -- ftp transfer type
check-certificate -- https certificate validation
dst-path --
duration --
host --
http-data -- POST or PUT request body data
http-header-field -- add http header fields
http-method --
keep-result -- depracated, use 'output' argument
mode --
once --
output -- where to output data, works for all protocols
password --
port --
src-address -- source address for HTTP, HTTPS only
src-path --
upload -- ftp and tftp transfer direction
user --
without-paging --
[admin@rb951 home] > tool fetch url="https://api.telegram.org/bot5171614564: ... _id=169231
9314&text=azoz"
status: failed
failure: closing connection: <404 Not Found> 149.154.167.220:443 (4)
hussamaziz
Re: mikrotik send message to telegram
Fri Mar 04, 2022 11:04 am
normis
Fri Mar 04, 2022 11:22 am
Try other solutions already posted on the forum viewtopic.php?p=915946&hilit=telegram#p911742
nescafe2002
Forum Veteran
Forum Veteran
Fri Mar 04, 2022 12:25 pm
Wow normis, that is a lot of code for a simple api call :)
TS, this works fine:
/tool fetch url="https://api.telegram.org/bot123456789:abcdef/sendMessage?chat_id=123456789&text=testMsg" as-value output=user
note that the ? between sendMessage and chat_id is missing in your example.
diamuxin
Fri Mar 04, 2022 2:53 pm
My method in case it helps you.
First:
Buid module called "MyTGBotSendMessage" (is a simple script)
:local BotToken "XXXXXXXXXX:XXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXX";
:local ChatID "XXXXXXXXX";
:local parseMode "HTML";
:local SendText $MessageText;
/tool fetch url="https://api.telegram.org/bot$BotToken/sendMessage\?chat_id=$ChatID&parse_mode=$parseMode&text=$SendText" keep-result=no;
:log info "Send Telegram message";
Second:
Module inside each script
# START Send Telegram Module
:local DeviceName [/system identity get name]
:local MessageText "\E2\9A\A0 $DeviceName: <Text or variables to send to telegram>";
:local SendTelegramMessage [:parse [/system script get MyTGBotSendMessage source]];
$SendTelegramMessage MessageText=$MessageText;
# END Send Telegram Module
Good luck!
Lilarcor
Thu Jun 16, 2022 10:27 am
quite useful, thank you.
ingdaka
Trainer
Trainer
Fri Jun 17, 2022 10:12 pm
Also you can check videos of this guy https://www.youtube.com/c/ErionDemiri
Users browsing this forum: GoogleOther [Bot] and 80 guests
