fpawlak
Is still ipsec fasttrack bypass rule needed in ROS7
Mon Mar 07, 2022 1:49 pm
Hi guys,
simple question about ipsec and fasttrack.
With ROS7+ do I still need to add 'bypass rule'?
eg.
/ip firewall mangle add action=mark-connection chain=forward comment="Mark IPsec" ipsec-policy=out,ipsec new-connection-mark=ipsec
/ip firewall mangle add action=mark-connection chain=forward comment="Mark IPsec" ipsec-policy=in,ipsec new-connection-mark=ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment=FastTrack connection-mark=!ipsec connection-state=established,related
I have seen something similar on default config on my CAP ac after upgrade to ROS 7.1.3 so probably is still needed
g18c
Re: Is still ipsec fasttrack bypass rule needed in ROS7
Thu Jun 30, 2022 7:38 am
Yes still needed.
Braddock
Fri Oct 21, 2022 12:41 pm
I have a question regarding the mangle rules that mark ipsec connections to be skipped by fasttrack:
Do the mangle rules have to check every packet, or is it good enough to mark only packets with connection-state=new ?
Something like this:
/ip firewall mangle add action=mark-connection chain=forward comment="Mark IPsec" connection-state=new ipsec-policy=out,ipsec new-connection-mark=ipsec
/ip firewall mangle add action=mark-connection chain=forward comment="Mark IPsec" connection-state=new ipsec-policy=in,ipsec new-connection-mark=ipsec
Sob
Mon Oct 24, 2022 12:27 am
New is enough. That's the point, connection tracking recognizes to what connection each packet belongs, so once you mark connection, you can use just connection-mark=XXX as condition, when you need do to something else with packets that belong to this connection. You don't have to test each packet against all other possibly complicated conditions.
Users browsing this forum: akakua, Google [Bot], panzermaster18, Valerio5000, yoq and 192 guests
