kd7vea
what options for 2 factor authentication for VPN access
Thu Mar 10, 2022 5:25 pm
I have been looking at options for setting up 2-factor authentication when connecting to a Mikrotik VPN. I have seen Rublon and Miniorange as probably the most referenced options, but I'm wondering if anyone here has an open-source/free option that works. My organization is not against paying for a solution, but if there is an option that doesn't need to be paid for, that is always preferred. This is a mandatory item for Cyber security insurance, so I am just looking at all of my options. Yes we can self-host, and we do have our own SMS gateway if that's required. Thanks
404Network
Re: what options for 2 factor authentication for VPN access
Thu Mar 10, 2022 6:56 pm
Hmm I wonder if hotspot, user manager etc........ could provide some sense of authenticated login.............
I am not aware of 2 factor authentication like a rolling code device, or popup on the smartphone or via any one of the popular apps for smart phones yet being available for RoS.
Read this thread for ideas!!!
viewtopic.php?p=911961&hilit=two+factor ... on#p911961
holvoetn
Thu Mar 10, 2022 8:19 pm
Hotspot could be an option but it's not functioning correctly in ros7.
Should be fine with ros6.
I am interested in other options too...
kd7vea
Thu Mar 10, 2022 8:42 pm
Thanks, I will check out the article and look into Hotspot. I think this will be a fun project or at least a learning experience. I never know which one to expect.
jprietove
Trainer
Trainer
Thu Mar 10, 2022 8:58 pm
You can use Radius for authentication purpouse and enable any of the many 2FA plugins. Check, as an example, FreeRadius with Google Authenticator or Latch (from ElevenPath)
kd7vea
Thu Mar 10, 2022 9:19 pm
Thanks, This looks like it may be the way to. Ill do some research.
kreload
Fri Mar 11, 2022 4:56 am
2FA on mikrotik can be users-passwords + certificates. If you want MFA, probably external radius.
kd7vea
Wed Mar 16, 2022 4:06 pm
We are using user passwords and certificates already, but the insurance company says that does not qualify as 2 factor (we had the same thought) We got radius working yesterday so today I am going to try to tackle Google authenticator. we spent a few hours running the freeradius debugger to find all the little pieces that aren't covered in the tutorials
anav
Wed Mar 16, 2022 5:44 pm
Good work! Keep us up to date on progress!!
PackElend
Mon May 16, 2022 4:25 pm
would be great if you share them.
By the way, using https://www.notakey.com/products/ might a less headache alternative, depending on the amount of users.
The tutorial is here: https://gintskirsteins.medium.com/free- ... 2b5ae6d2de
A different but related question, would it be possible to use WireGuard VPN, which lands the user on a Hotspot?
holvoetn
Mon May 16, 2022 4:30 pm
Theoretically: why not ? It's an interface carrying IP like so many other ones.
PackElend
Mon May 16, 2022 4:44 pm
Theoretically :lol:
I haven't done a WireGuard setup yet and I'm still a hotspot newbie, despite viewtopic.php?p=933317#p933317.
I was hoping to find instructions on how to do it properly.
jcortega
Tue May 17, 2022 1:29 pm
You can use the user-manager package in ROS7.
You can add users with their pass and the OTP parameter in order to use it with Google Authenticator
pandreozzi
Mon Aug 15, 2022 5:07 pm
I love Mikrotik. The answers always seem to be Hmmmm or it should work.
Why don't they have definitive answers.
That's why people use Juniper and Cisco. More money for sure but at least you know it will work.
anav
Mon Aug 15, 2022 7:28 pm
Sounds like you also fornicate with your juniper and crisco devices.
If you want someone to hold your hand, look elsewhere.
kingslavcho
Fri Feb 03, 2023 9:34 pm
As i understood here, there is no free option to use 2FA for Mikrotik routers!?!? If i want a free radius to validate my logins i will have to run it on a server and forward the router to that server!?
Users browsing this forum: hatred, mszru and 70 guests
