Based on his other questions, its a relatively long standing problem, so probably not a homework question.Is this a typical network one sees in the field or is it a homework question??
Unfortunately it's a real scenario, any suggestion would be appreciated...Based on his other questions, its a relatively long standing problem, so probably not a homework question.Is this a typical network one sees in the field or is it a homework question??
But it is mostly one way, a taker not a giver.
I agree.. I'll see what I can do...That sounds like a management nightmare. Most people use dmvpn for such a use case. No matter what you do, your going to want to automate everything. if you can script then use your language of choice, if you can't then look into ansible. good luck, as that's a huge undertaking
So inquiring minds what to know.When you have a network like that, with 50+ nodes, EoIP (or L2TP ethernet bridging) is the LAST thing you want to use!
True, but it can be spun up on, and ran off of almost any linux box. but then your adding complexity, cost and reliability issues.zerotier is not available on all models and thus a cautionary offering.![]()
As per the OPs notes; "Every firewall site is a Mikrotik device."True, but it can be spun up on, and ran off of almost any linux box. but then your adding complexity, cost and reliability issues.zerotier is not available on all models and thus a cautionary offering.![]()
I had Bad experiences with EoIP, I would not consider it.If you have Mikrotiks on both ends, then EoIP with IPSEC should give you best "wireline compatible" link.
It could be an idea but since I have also tile, mibpse devices and so on, it can't be a way.True, but it can be spun up on, and ran off of almost any linux box. but then your adding complexity, cost and reliability issues.zerotier is not available on all models and thus a cautionary offering.![]()
Wanna laugh?Nobody asked what is the current solution that he uses.
Also you can scratch OpenVPN from that list as OpenVPN and RouterOS aren't friends yet.
Do you have any configuration with keepalive active?Ok I use GRE/IPsec (and also without IPsec) and L2TP/IPsec in production on routers with TILE and MIPSBE on RouterOS v6 without any issues.
I use BGP on top of that for the routing, others use OSPF (may be better suited, I have no practical experience with it).
I always configure GRE without keepalive, it is known to be a problem in interoperability.Do you have any configuration with keepalive active?
What is your setup with DPD?
There are more than 60 routers (Mikrotik)... and yes usually it's something like 22/6 and 24/7Sounds like a real challenge. How many routers are there in total and how many are working full time with network operations? Any requirements on uptime like 24/7 operations or throughput?
We have a hobby network with more routers than that. There is a central router where about 60 routers connect, but there are wireless connections between them and to other routers that have no internet VPN connection.There are more than 60 routers (Mikrotik)... and yes usually it's something like 22/6 and 24/7
About throughput there's no requirements.
If you read the whole thread, one of my answer was:What type of business or location is this that has a network of 60 plus MT devices and no throughput requirements ????
THe only thing I can think of are factories with machinery that reports status (very low throughputs required) but they have specialized equipment for that.
This is why, in my work network, the sites have 3 tunnels:Throughtput is usually limited to few Mbps... not more than 10 Mbps to make you understand better.
The customer just can't lose the connection to HQ servers
Well, then you have plenty of unpaid manpower that is quite something else compared to regular business operations with 22/6 or 24/7 requirements.We have a hobby network with more routers than that. There is a central router where about 60 routers connect, but there are wireless connections between them and to other routers that have no internet VPN connection.
60 routers located over a large geographical area is a huge undertaking. To find a network protocol and architecture that fits your needs is just a small part of getting all together.There are more than 60 routers (Mikrotik)... and yes usually it's something like 22/6 and 24/7
The challenge is that this manpower is largely uncoordinated and not expert in network configuration and operation.Well, then you have plenty of unpaid manpower that is quite something else compared to regular business operations with 22/6 or 24/7 requirements.We have a hobby network with more routers than that. There is a central router where about 60 routers connect, but there are wireless connections between them and to other routers that have no internet VPN connection.
Yeah, or if you are surrounded by self-appointed "network experts", each with their own view on what's the best network configuration. ;- )The challenge is that this manpower is largely uncoordinated and not expert in network configuration and operation. Usually it is easy to get a new node running, the challenge is to prevent them from fouling it up later (e.g. by clicking in the "Quick Set" screen or upgrading to RouterOS v7).
- Luckily only L3- Any requirements on L2 or just plain L3 networking?
- What's most important, speed or stability?
- Do you have an existing management network in place?
- Tools in place for network monitoring, management and configuration?
- Are all the routers up and running thus you are forced to use remote configuration or are you able to configure and test units in a local lab env before sending it to customer?
- Any backup access (eg LTE) if configuration breaks?
- Manpower for network and configuration management during installation and later for day to day operations?
