faysalsy
Find a comment that doesn't contain a specific text
Mon Mar 14, 2022 9:56 pm
How to find a comment that doesn't contain a specific text
 /ip hotspot user [ find comment~"a" ]
But I want to find a comment that doesn't contain the text "a" for example.
Jotne
Re: Find a comment that doesn't contain a specific text
Mon Mar 14, 2022 10:03 pm
/ip hotspot user find comment!~"a"
~ Does contain
!~ Does not contain
NB do not use [] in the way you did.
You can also mix and match:
/ip hotspot user find comment!~"a" comment~"b"
to get result to a variable:
:local test [/ip hotspot user find comment!~"a" comment~"b"]
faysalsy
Mon Mar 14, 2022 10:13 pm
:loc d [/system clock get date];
 :local mo [:pick $d 0 3];
/ip h u remove [ find  comment!~ "$mo" ]
dont work
but if
/ip h u remove [ find  comment~ "$mo" ]
it work
eworm
Re: Find a comment that doesn't contain a specific text  [SOLVED]
Mon Mar 14, 2022 11:55 pm
/ip hotspot user print where !(comment~"a")
Users browsing this forum: No registered users and 26 guests
