emils
Forum Veteran
Forum Veteran
v6.49.5 [stable] is released!
Wed Mar 16, 2022 9:41 am
RouterOS version 6.49.5 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.49.5 (2022-Mar-14 13:31):
*) defconf - fixed invalid default password setting after configuration reset (introduced in v6.49.4);
*) sfp - improved SFP module detection on CRS106 and CRS112;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
pe1chl
Re: v6.49.5 [stable] is released!
Wed Mar 16, 2022 11:14 am
Can you explain that in more detail? Does this mean one can get locked out doing a full reset to defaults?
Or is it "only" related to the recently introduced prompt to change the password when it is empty?
I reset a router running 6.49.4 to defaults yesterday but it was with "keep user configuration" and nothing bad happened.
mrz
Wed Mar 16, 2022 11:29 am
If factory settings had wps sync key on the Audience, then after reset this key was set as user password.
pe1chl
Wed Mar 16, 2022 11:58 am
It only affected Audience?
That in effect makes this release only relevant to Audience, CRS106 and CRS112?
pothi
Wed Mar 16, 2022 12:02 pm
Thank goodness. I didn't reset the config since last version due to multiple reasons. I am glad I didn't.
Pl07R3K
Wed Mar 16, 2022 8:36 pm
There are prohibited CAPsMAN rates above mcs-23.
[xxx@xxx] > /caps-man rates set 0 ht-supported-mcs=
HtSupportedMcs ::= mcs-0|mcs-1|mcs-2|mcs-3|mcs-4|mcs-5|mcs-6|mcs-7|mcs-8|mcs-9|mcs-10|mcs-11|mcs-12|mcs-13|mcs-14|mcs-15|mcs-16|mcs-17|mcs-18|mcs-19|mcs-20|mcs-21|mcs-22|mcs-23[,HtSupportedMcs*]
[xxx@xxx] > /interface wireless set wlan2 ht-supported-mcs=
HtSupportedMcs ::= mcs-0|mcs-1|mcs-2|mcs-3|mcs-4|mcs-5|mcs-6|mcs-7|mcs-8|mcs-9|mcs-10|mcs-11|mcs-12|mcs-13|mcs-14|mcs-15|mcs-16|mcs-17|mcs-18|mcs-19|mcs-20|mcs-21|mcs-22|mcs-23|mcs-24|mcs-25|mcs
-26|mcs-27|mcs-28|mcs-29|mcs-30|mcs-31[,HtSupportedMcs*]
Amduscia
Thu Mar 17, 2022 11:55 am
AC2, 2011 wifi - works after the update as always well
pothi
Thu Mar 17, 2022 6:25 pm
Updated hAP ac^2 and SXT LTE kit to the latest version. Both have been normal so far.
woland
Thu Mar 17, 2022 7:12 pm
updated some CAPacs , a CRS 309, a HEXS with out Problems. Then I had to climb up to a HEX PoE to powercycle it. It did not respond to ping/macping, the ports stayed up, but no traffic was flowing. It´s used as a PoE Switch only, no routing. Update was from 6.49.4 > 6.49.5.
BR
W
brandaoeb
Fri Mar 18, 2022 2:10 pm
With new update 6.49.5 on CRS112 ubiquit SPF modules UF-RJ45-1G do not work anymore. Going back on firmware (Long Term) OK. Iam not sure but 6.49.3 was working.
sirca
Sun Mar 20, 2022 5:04 am
CRS305
CRS326
CRS317
CHR
no issues
Best Regards From Rome :)
Marc66FR
Tue Mar 22, 2022 1:44 pm
Upgraded hEX from 6.49.4 to 6.49.5. Worked OK but had some issues connecting to some sites (Apple updates, Youtube). Rebooted the router and seems to work fine now.
Pl07R3K
Thu Mar 24, 2022 6:00 pm
It is still not possible to configure HT MCSs for the four spatial streams in CAPsMAN rate.
[piotr@aPoint] <SAFE> /caps-man rates set 0 ht-supported-mcs=msc-24
syntax error (line 1 column 40)
kehrlein
Sat Mar 26, 2022 6:44 pm
Updated soft- and firmware on these models without any issues:
CRS112-8P-4S
RB750GL
RBcAPGi-5acD2nD (cAP XL ac)
RB1100AHx4
CCR2004-1G-12S+2XS
CCR1009-7G-1C-1S+
x86
edit: added more models
mahfuzazam
Wed Mar 30, 2022 10:43 am
Updated below models without any issues so far:
- 2 CCR-1036
- 3 RB4011
- 2 RB3011
- 1 hAP ac3
Strange thing is, my RB2011 is not getting the latest stable update from the /system/packages/ menu.
pe1chl
Wed Mar 30, 2022 11:08 am
You need to investigate why that is! Strange fixed DNS entries, scripts you did not create, etc.
mahfuzazam
Wed Mar 30, 2022 1:20 pm
Nothing is wrong from the router end. No unwanted scripts, rules, DNS entries are found. I'll perform netinstall shortly after and will check if that works or not.
pe1chl
Wed Mar 30, 2022 1:30 pm
Do you get some error message (unable to resolve DNS name, timeout when connecting) or does all seem OK but it shows no available update?
mahfuzazam
Wed Mar 30, 2022 1:52 pm
The router only shows no available update and is installed to the latest version 6.49.4.
Apart from this, all services are okay and I'm not having any network issues at all. To be honest, this is for my home lab, and the router does not contain any complicated configurations. Just some firewall rules, DHCP, simple natting, etc.
pe1chl
Wed Mar 30, 2022 4:31 pm
While it is a bit worrying that your router does not show available updates (that might point to it being hacked and now updates are being controlled by someone other than MikroTik), there is no reason to install 6.49.5 on a 2011.
When you have time you can try do a /export, examine it for things that you put not in there yourself, then do a netinstall with format and no default settings, and then connect using MAC and upload and import the /export file again.
When you use version 6.49.4 for that you can then again try to see if it shows the update. But you can also immediately go to 6.49.5.
mahfuzazam
Wed Mar 30, 2022 7:26 pm
Yes. I'm planning on netinstalling later tonight. I've gone through the configs and everything is as it should be. Already had the 2011 reset couple of times, but no luck. Let's see and observe what happens. Funny thing is, my hEX and RB450G detect 6.49.5. So, need to investigate my RB2011 further.
emils
Forum Veteran
Forum Veteran
Wed Apr 13, 2022 2:14 pm
New version v6.49.6 has been released:
viewtopic.php?t=185067
Users browsing this forum: No registered users and 17 guests
