AstroPig7
VLAN with Wifiwave2
Fri Mar 18, 2022 3:07 pm
I apologize if this has been asked before, but searching the forums didn’t return an exact answer. Before switching to the Wifiwave2 package, I was able to set the vlan-id for a wireless interface directly in said interface. After switching to Wifiwave2, I’ve found the vlan-id and vlan-mode options are gone from the interfaces. I’m using a hAP ac³, and I normally perform port-based VLAN tagging at the switch level (with a CRS112-8P-4S-IN), but I can’t do that in this case because the tags only go on a guest interface that’s subordinate to the 5 GHz interface. Is my only option to tag the interface at the bridge? If so, then is this done by setting the pvid of the interface?
gotsprings
Re: VLAN with Wifiwave2  [SOLVED]
Fri Mar 18, 2022 3:56 pm
you have to do it in VLAN FILTERING in the WAVE 2 package.
https://wiki.mikrotik.com/wiki/Manual:I ... s_Ports.29
holvoetn
Fri Mar 18, 2022 3:57 pm
On the Help page for wifiwave2, there is a reference which might be of assistance.
Never done it myself, though.
Assigning VLAN tags to wireless traffic can be achieved by following the generic bridge VLAN example here:
https://help.mikrotik.com/docs/display/ ... ccessPorts
AstroPig7
Fri Mar 18, 2022 4:11 pm
All right, so it seems I now have to do it through the bridge port configuration. Easy enough!
jimint
Mon Jan 01, 2024 5:37 pm
Is it possible to write here your config with wifiwave2 and vlans please?
mkx
Mon Jan 01, 2024 6:24 pm
Nothing about VLANs under /interface/wifi (or wifiwave2 ... it's been renamed in 7.13). So the config gives you a number of wifi interfaces (probably named wifi1, wifi2, etc.).
Then under /interface/bridge something like this:
set [ find name=bridge ] vlan-filtering=yes
/interface/bridge/port
add bridge=bridge interface=wifi1 frame-types=admit-only-untagged-and-priority-tagged pvid=13
add bridge=bridge interface=wifi2 frame-types=admit-only-untagged-and-priority-tagged pvid=666
# ... and optionally, doesn't have to be set explicitly, ROS adds ports with pvid set to appropriate VLANs automatically
/interface/bridge/vlan
set [ find bridge=bridge vlan-id=13 ] untagged=wifi1
set [ find bridge=bridge vlan-id=666 ] untagged=wifi2
So nothing really special, simply treat wifi interfaces as access ports for appropriate VLANs, just like you'd do for ether ports. The vital thing is to have vlan-filterig enabled on bridge, otherwise this won't work.
jimint
Mon Jan 01, 2024 7:35 pm
Thank you so much i will check it
I forgot to inform you that i have my main router 4011 with already vlans (GuestWifi-IOTWifi-MainWifi) and in my room i have ac2 with 7.13 Ros and the new drivers wifiwave2. So i would like with vlans ID from 4011 to have all subnets (GuestWifi-IOTWifi-MainWifi) from main router.
mkx
Mon Jan 01, 2024 11:58 pm
So you need to set up ethernet link between RB4011 and hAP ac3 as trunk (tagged for all necessary VLANs).
Users browsing this forum: Semrush [Bot] and 86 guests
