gezir
router Upgrade problem "routeros-powerpc-7.1.3.npk missing, use ignore-missing or disable package(s)"
Mon Mar 21, 2022 8:32 pm
I try to upgrade my router os from 6.49.5 to 7.1.3 but getting error :
screen shot is attached
My router is RB1100
pateutz
Re: router Upgrade problem "routeros-powerpc-7.1.3.npk missing, use ignore-missing or disable package(s)"
Mon May 02, 2022 8:08 pm
Hello
it is quite annoying but i believe that is happening the reason of the package name for PPC ( powerpc) have changed.
Example:
For the 6.xx version the package name is routeros-powerpc-6.xx.xx.npk
https://download.mikrotik.com/routeros/ ... 6.48.6.npk
For the 7.xx version the package name is routeros-7.2.2-ppc.npk
https://download.mikrotik.com/routeros/ ... .2-ppc.npk
The only solution is to run the upgrade for this architecture, for now, by downloading the routeros-7.x.x-ppc.npk on your PC and the uploading it to the router.
After the file is uploaded reboot the router to proceed with the upgrade.
Best Regards,
Daniel
Users browsing this forum: Google [Bot], zhenb and 52 guests
