CHR
Code: Select all
# mar/22/2022 13:11:19 by RouterOS 6.44.3
# software id =
add arp=proxy-arp fast-forward=no name=clients priority=0x8192 \
transmit-hold-count=1
set [ find default-name=ether1 ] disable-running-check=no
add name=clientpool ranges=10.8.0.1-10.8.127.255
/ppp profile
add bridge=clients local-address=10.8.0.1 name=clientProfiles remote-address=\
clientpool use-encryption=yes
add bridge=clients interface=ether1
add bridge=clients interface=*F005C9
add bridge=clients interface=*F004E9
add bridge=clients interface=dynamic
/interface ovpn-server server
set auth=sha1 certificate=ServerCert cipher=aes256 default-profile=\
clientProfiles enabled=yes keepalive-timeout=30 netmask=17
/ip dhcp-client
# DHCP client can not run on slave interface!
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip firewall address-list
# 4000 units have been added to the list, but removed here for brevity
add address=10.8.40.1 list=undeployed
add address=10.8.80.23 list=test
add address=10.8.80.24 list=test
add address=10.8.87.207 list=undeployed
"Allows members of the test address list to communicate." \
dst-address-list=test src-address-list=test
"Allows all traffic from Internal Trusted Servers to units." \
dst-address-list=!InternalTrustedServers src-address=0.0.0.0 \
src-address-list=InternalTrustedServers
"Allows all traffic from units to Internal Trusted Servers." \
dst-address-list=InternalTrustedServers
add action=accept chain=forward comment="Test of unit to unit communication" \
disabled=yes dst-address-list=test src-address-list=test
"Accept Forward for Established and Related Connections" \
add action=accept chain=forward comment="Allow Forwarding by OVPN Clients" \
src-address=192.168.22.128/25
"Accept Input for Established and Related Connections" connection-state=\
add action=accept chain=input comment="Allow OpenVPN Connection" dst-port=\
1194 protocol=tcp
add action=accept chain=input comment="Allow Input by OVPN Clients" \
in-interface=all-ppp
add action=accept chain=input comment="Allow Winbox Input" dst-port=8291 \
protocol=tcp
add action=accept chain=input comment="Allow HTTPS Input" dst-port=443 \
protocol=tcp
add action=drop chain=input comment="Input drop for all other connection" \
disabled=yes
add action=drop chain=forward comment="Forward drop for all other connection" \
disabled=yes
add action=drop chain=forward comment="Invalid drop for all other connection" \
connection-state=invalid disabled=yes
add action=drop chain=forward comment="PREVENT ALL TALK BETWEEN UNITS." \
disabled=yes src-address=!10.8.0.5
add action=masquerade chain=srcnat out-interface=all-ppp
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=UNIT1 profile=clientProfile remote-address=10.8.80.1 service=ovpn
add name=UNIT23 profile=clientProfile remote-address=10.8.80.23 service=\
ovpn
add name=UNIT24 profile=clientProfile remote-address=10.8.80.24 service=\
ovpn
add name=UNIT4000 profile=clientProfile remote-address=10.8.47.207 service=\
ovpn
/system identity
set name=CHRserver
/system logging
add topics=ovpn
add topics=debug
Client
Code: Select all
# feb/18/2022 15:56:20 by RouterOS 6.48.3
# software id = QR61-PILT
# model = RBM33G
# serial number = A2FD0E5B89AE
add arp=proxy-arp mtu=1350 name="S2LAN Bridge"
add fast-forward=no name=bridge1
set [ find default-name=ether1 ] arp=proxy-arp l2mtu=1500
set [ find default-name=ether2 ] arp=proxy-arp l2mtu=1500
set [ find default-name=ether3 ] arp=proxy-arp l2mtu=1500
/interface ovpn-client
add add-default-route=yes certificate=client.crt cipher=aes256 \
connect-to=[PUBLIC IP] mac-address=FE:AB:ED:98:94:4A name=ovpn-out2 \
user=UNIT24
/interface lte apn
set [ find default=yes ] add apn=[APN NAME] name=APN
/interface lte
set [ find ] apn-profiles=APN name=lte1
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=LoRa supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] arp=proxy-arp band=5ghz-a/n/ac country=\
"united states" disabled=no frequency=auto mode=ap-bridge radio-name=\
UNIT24 scan-list=5180,5200,5220,5240,5745,5765,5785,5805,5825 \
security-profile=LoRa ssid=UNIT24 station-roaming=\
enabled wds-default-bridge="S2LAN Bridge" wds-default-cost=50 \
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] arp=proxy-arp band=2ghz-onlyg \
basic-rates-a/g=6Mbps,12Mbps,18Mbps,24Mbps basic-rates-b="" country=\
"united states" disabled=no disconnect-timeout=6s frequency=2437 \
hw-protection-mode=rts-cts hw-retries=3 max-station-count=64 mode=\
ap-bridge multicast-helper=full nv2-cell-radius=10 nv2-downlink-ratio=20 \
nv2-security=enabled radio-name=UNIT24 scan-list=2412,2437,2462 \
security-profile=LoRa ssid=Wi-Fi_LR station-roaming=\
enabled supported-rates-a/g=6Mbps,12Mbps,18Mbps,24Mbps supported-rates-b=\
"" wds-default-bridge="S2LAN Bridge" wds-mode=dynamic-mesh \
add name=pool1 ranges=192.168.2.101-192.168.2.102
add name=dhcp_pool1 ranges=10.8.0.101-10.8.0.200
add address-pool=dhcp_pool1 disabled=no interface="S2LAN Bridge" name=dhcp1
/ppp profile
set *0 bridge-path-cost=1500
add bridge="S2LAN Bridge" bridge-path-cost=1500 name=ppp_bridge \
use-encryption=yes
/queue type
add kind=pcq name=custom pcq-classifier=\
src-address,dst-address,src-port,dst-port pcq-dst-address6-mask=64 \
pcq-limit=10KiB pcq-src-address6-mask=64
/queue interface
set wlan1 queue=custom
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge="S2LAN Bridge" interface=wlan1 multicast-router=disabled
add bridge="S2LAN Bridge" interface=wlan2 multicast-router=disabled
set enabled=yes loose-tcp-tracking=no tcp-syn-received-timeout=15s \
tcp-syn-sent-timeout=15s
set discover-interface-list=all
add address=192.168.2.1/24 interface=bridge1 network=192.168.2.0
add address=10.8.80.24/17 interface="S2LAN Bridge" network=10.8.0.0
add address=10.8.0.0/17 gateway=10.8.0.1 netmask=17
add address=192.168.2.0/24 dns-server=1.1.1.1 gateway=192.168.2.1
add action=masquerade chain=srcnat comment="NAT masquerade" \
out-interface="S2LAN Bridge"
add action=dst-nat chain=dstnat comment="BCP 4002 - redirect to pi DST-nat" \
dst-address=10.8.80.24 dst-port=4002 in-interface="S2LAN Bridge" \
protocol=tcp to-addresses=192.168.2.2
add action=dst-nat chain=dstnat comment="Access Front Cam RTSP DST-NAT" \
dst-address=10.8.80.24 dst-port=8500 protocol=tcp to-addresses=\
192.168.2.8 to-ports=8500
dst-address=10.8.80.24 dst-port=9500 protocol=tcp to-addresses=\
192.168.2.9 to-ports=9500
add action=dst-nat chain=dstnat comment="Access Front Cam HTTP DST-NAT" \
dst-address=10.8.80.24 dst-port=8001 protocol=tcp to-addresses=\
192.168.2.8 to-ports=80
dst-address=10.8.80.24 dst-port=9001 protocol=tcp to-addresses=\
192.168.2.9 to-ports=80
add action=dst-nat chain=dstnat dst-address=10.8.80.24 dst-port=6000-6999 \
in-interface="S2LAN Bridge" protocol=udp to-addresses=192.168.2.2
add action=dst-nat chain=dstnat dst-address=10.8.80.24 dst-port=33 protocol=\
tcp to-addresses=192.168.2.2 to-ports=22
add action=src-nat chain=srcnat out-interface=lte1 src-address=192.168.2.2 \
to-addresses=10.80.47.99
/ip ssh
set always-allow-password-login=yes
/system clock
set time-zone-autodetect=no time-zone-name=Etc/UTC
/system identity
set name=UNIT24
/system leds
add interface=wlan1 leds="wlan1_signal1-led,wlan1_signal2-led,wlan1_signal3-le\
d,wlan1_signal4-led,wlan1_signal5-led" type=wireless-signal-strength
add interface=wlan1 leds=wlan1_tx-led type=interface-transmit
add interface=wlan1 leds=wlan1_rx-led type=interface-receive
/system logging
add topics=ovpn,debug
/system routerboard settings
set boot-delay=5s boot-device=nand-only
/system scheduler
add interval=30s name=modemScript on-event=NatLTEIPFix policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jan/01/1970 start-time=00:00:00
/system script
add dont-require-permissions=no name=NatLTEIPFix owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
global currentIP;\
\n\
\n:local newIP [/ip address get [find interface=\"lte1\"] address];\
\n\
\n:if (\$newIP != \$currentIP) do={\
\n :put \"ip address \$currentIP changed to \$newIP\";\
\n :set currentIP \$newIP;\
\n /ip firewall nat set [find action=src-nat] to-address=\$currentIP\
\n /ip firewall connection remove [find]\
\n}"
/tool romon
set enabled=yes
